Killer Chiller installed / heat exchanger removed = 50 degree IATS !
I did get it to spike to 135 ish and it wasnt all that long of a run. I believe it was 0-115 range. I dont think I let the water totally cool on that run but still. I had it running at 65-70 IATs going uphill today and a quick blast from 35 to 75 it peaked at 125
Seems to just heat up so fast with the AC not cooling the water and no HE to help once the water heats up.
Seems to just heat up so fast with the AC not cooling the water and no HE to help once the water heats up.and if your AC ever fails (what MB ac fail? no way!
) then better hope your ECU pulls timing quick enough and you go into limp mode before any detonation occursi think the kc is great for city driving and such but just not for long stints of wot... need a fail safe for that and HE currently is that.... plus it only raises iat 15f according to KC
Since I know people will harass me for not saying , all I got was 11.8s-11.9s and a bunch of 12 flats. Best 60 foot was a horrible 1.95 60 on DRs .....
What was your 1/8 mile speed & et?
What PSI did you set your MT's?
How did you launch?
What was your suspension setting?
Edit: I missed you are actually using meth. I thought you were just using water. The 50/50 mix might be giving you the perfect mix so you dont have to mess with your fueling or at least not much. Would like to know more about your setup.
We already had the tune for the mods and fuel (both 93oct and Q16) and all we did was add the meth. We never retuned for it. It was only for cooling. And it worked. After a 4th gear pull to 184mph, the surge tanks would be ice cold to the touch. And the water in the trunk tank was 69 degrees. Did a back to back 4th gear pull and the trunk tank temps only went to 79 degrees. all in 92 degree weather (average for south FL).
I also have a Cobra HE mounted under my trunk to help cool the water before it goes back into my trunk tank.
here's a pic of the trunk and Cobra HE
do you have pics of the nozzles installed? and what size nozzles are you running?
i have been interested in doing this on the e55 but cant find much documentation on the setup and nozzle placement was pretty important on my audi S4 since too far up the y-pipes would cause pooling and I would see timing pulled (although i was tuned for meth and timing advancement)
How did you launch?
Trap was only 95.5 MPH in the 8th. I think the 8th mile might be high if I remember correctly. My GTO was trapping 97 MPH at the 8th and only 117 in the 1/4. It should be a solid 24-25 MPH back half on that car.
So my 1/8th was 7.6-7.7 @ 95 MPH on my 11.8 and 11.9 passes. What was very interesting is my MPH in the 8th stayed the same all day at 95 MPH. My 1/4 mile trap went from 121 to 119 down to 116s the last 5-6 runs.
. I think its safe to say all my timing was being pulled in the back half from high IATs. 26 MPH down to 21.5 MPH in the back half. Water was cold enough first part of the run and then I fell flat on my face the back half. MT were at 18 PSI at first. Later I set them to 22 and did better. Had it in sport mode and was power braking to 1200 RPM. Suspension I set to normal and also tried the other settings but they didnt seem to help or hurt things. I now know that I shouldnt be power braking. In fact with my chiller it was probably raising my IATs before launch. Man I wish I had my scanner . It would have helped so much to know what was going on. I just thought I was golden with the chiller.
The guy who installed it on my car doesnt think the water really had time to heat up that much. Instead he thinks it could be insufficient flow to the IC and it cant keep up or just the crappy IC design cant keep up. I just have the newer model bosh pump which is like 7-8 gal flow. Thinking about getting a 20 gal pump to see if it helps much.
Your tune may be off as well
when I was stock I was running 93.5 to a high of 94.2 in the 1/8. My best runs came with that setup I sold you at 20psi before the runs with a 1.71 60' launching off idle. Your car if running correctly should pick up about 27+mph in the back half......our setups are similar but I'm 8 tenths quicker in the 1/8 and about 7mph faster and around 7mph faster at the 1/4. When you go back to the track set your psi at 20, raise your suspension, turn your shock setting off and get a nice burning going with you rolling out hot and then power brake just long enough to take the slack out of the suspension and then let it go back down to idle and when you are ready after the light turns green very quickly step on the gas at the same (almost) time let your foot off the brake and if you don't run a better time with a better mph then you may have to look at your IAT or your tune.
Arent you trapping 125 MPH at sac ? I did trap 121 on my first pass. Wow you are trapping 102 in the 8th ? Atleast my 8th mile was the same from beginning to end which tells me the timing isnt being pulled much until the back half. I am wondering if Sac changed their 8th mile beams recently . It was reading a couple high last time I was out. Perhaps it is either correct now or a little low
They seem to play musical chairs with those beams.I am still running the canned/custom OE tune. I plan on doing a dyno session with OE but might wait until I get the new IC pump to see if it helps. I know one guy with similar mods said he picked up 60-70 WHP going from the canned tune to dyno tune . I imagine I would get a solid 30-40 anyway. I know it will make a big difference.
So you actually push the button that raises the car an inch ? I didnt remember that and I didnt even try that. Makes sense for weight transfer. I think the power braking was hurting me a bit too. I bet it was enough to shut down my chiller. I probably started with a good 30 degree higher IATs that I could have off idle. Burn out will heat it up good too. I
My biggest problem on most runs was spinning badly except for a couple runs. Some were well after the initial launch,
, So i can play too
