Dreaded p5050 p507 codes after 82MM TB switch
My car was set 550 default and that is really hard to hit with an 82tb I upped it to like 564-70 in star and you can't tell the difference with a scan tool looking at the tps and rpms
And is there anyone with an 82TB with no codes.
I'm looking install one on my car but after seeing this I'm worried.
If you have a rough idle it most def has some codes pending and star quick test prolly has 10 pending codes lol
I gave up and found an amg 78mm that would not throw any pending codes and just this week I decided to go to an 82tb again.
Not even 10 miles of driving the car pended the code so its not a leak as the only thing I swapped were the tb and the inlet was not touched.
Upped idle in star and almost 2 days no pending codes and car idles like stock
On the tps % you will pend a code at anything close to 1.2 tps and want to see 1.6-2.0 fully warmed up in drive idling
Thankss for sharing.....
ZAYED,,
Good Luck....
ZAYED,,
mentioned a possibility of problems shows-up after installing an 82mm TB kit,
although they are a great tuners(which provides 82mm TB kit)......
ZAYED,,
like air temp. sensor & charging air sensor, sometimes they may throw cells to the ECU,
and the ECU can’t deduct these kind of codes,
if you can put Star and drive the car for a while, then see what kind of codes you will find after the air & the water been hot.....
ZAYED,,
