White smoke on the startup
maybe install a catch can to see how much oil is collecting
http://autoplicity.com/products/2362...gn=GSNOFITMENT
Good luck with it man. Maybe it's just a leaky valvestem or something. I used to get a small puff on startup on my Typhoon, but it was more of a white/blue puff indicating oil. As they've said here, all white = coolant/moisture
I'm not finding any shop time estimates, but the gaskets are 75-80 bux a piece depending on what side.
If you saw smoke all the time then it could be either coolant related (most likely a head gasket) or oil related (most likely valve guides or possibly a ring issue). Either way you can test easily for both scenarios if you are concerned.
Not sure where you live but around this time of year we have in Canada cool evenings and then it warms up through the day. Condensation is normally seen a white,light, with little smell, of course as long as you still have the cats in place. As others have stated oil should not be milky, oil filler cap should not show condensation, and also coolant level in expansion tank should be checked daily/weekly to ensure no level change. Always check when stone cold for accurate measure. Avoid short runs where oil temp does not come up to normal, you will notice on one of the screens that the engine oil temp will flash until it reaches 80c which will take longer than the coolant temp. Good luck, do not worry yet!
