PAS6201 E55 Build Thread
#427
Former Vendor of MBWorld
We did go with larger injectors on the build. As far as the looped fuel rail, I havent seen any hard evidence yet that it really helps that much. I could be wrong but some guys are already in the 10's without it.
#429
2003 porsche 996 turbo
fwiw i tested a looped rail setup on my 32. with the oem setup the fuel hits the wall and pressure builds back. with the loop the pressure was lower showing that the pressure shown on a gage would be across all the injectors when in fact it isnt. i dropped 5 psi from oem to a looped setup reading from the same spot. this told me pressure builds from the front of the engine back to the rear injectors and the lower pressure reading was what was really being used
i saw your car at ips during timmayfest. they are doing some first class work!
#430
we are designing a basic kit to be as bolt on as possible so that the customer has to do little to no other mods to get this thing to fit/work
#431
with the amount of work you have invested in this build why not consider e85 for fueling? runs cooler has the same effect as race fuel at a lower cost and allows for huge boost!
#432
#433
#435
Our ECU's are not designed for it and E85 has tons of quality issues. When they say "E85", they really mean E70 to E85. Running E85 in our cars is really playing with fire.
#436
Looks great! This thing's going to be really fast. What are you shooting for deep 9s?
#441
Thanks guys! I think it will sound great too. Hopefully have a video of idle by next week:-) Not shooting for 9's yet. Just want to get this base kit running and tested. After that is done it will be time to go crazy with it. Rain wont be a problem. There will be a skid plade protecting the turbos.
#445
I seriously doubt that. Why would you handicap yourself building a heavy platform with a difficult engine control system if you were just going to make it obnoxiously loud and wreak of CO and HC like a race car?
#446
Thank you Chris! Yes the car will have an exhasut system. It wont have any cats or resenators. But will have mufflers!
#448
