M156 cam adjuster noise and oil change
I had had 2 oil changes where the filter did not hold onto the cap so when I removed it, it had a mess.
You see, the filter element should hold onto the cap with plastic clips. When you unscrew the cap the oil filter lifts with it and a spring loaded valve at the bottom of the oil filter housing opens and allows the oil to drain. If the oil filter does not lift from the valve, the only place for the oil to go is out the top. Meaning, a mess.
So previous oil change I screwed in the cap and then unscrewed it to ensure the filter stayed with the cap. It didn't the first time, so I reapeated until it did. In other words, "I messed with it".
After that oil change, I got the valve adjuster noise during start up (about 50% of the time always after some period of time with the enginer off). Knowing they are hydraulic, my intuition told me.. "you messed with the oil filter and now the oil is draining".
Well, could not see any problems with the filter on my next change, but this time I did not "mess with it". The noise is gone. At least so far.
My questions are:
1. If the oil was draining from the filter when the engine was off, would valve adjuster noise on start-up be expected?
2. If yes, would damage be expected?
Note, oil analysis is pending. I have 4 prior analysis, so a good baseline.
Thoughts? Wisdom? Documentation?
Just an FYI
Well, oil analysis should be done soon and we will see if any negative effects.
But one day the lifters were making noise for about 4 miles of driving..oil temp was normal car fully up to operational temp....
I got pissed and rip 1-3 in Sport Mode...after that she ran like a Toyota...
I must say I had no real issue with this car....Wish the new owner the same...RIP but being rebuild...
But for my Mazda with almost 300k...lol Start and go so I can get heat.. The higher end car needs more love... Love me Mazda...
