Let's talk mods.
Old Aug 31, 2003 | 01:10 PM
Rave E55's Avatar
Let's talk mods.
Renntech seems to offer a decent mod (ecu & pully), what other, reasonably priced mods are available?
EVO is supposed to come out with an ecu & pully upgrade, is evo a reliable company for such products? (No offense to the guy's at evo). Would you go with EVO or Renntech?
Is a differential mod available?
Can the car be lowered by manipulating the electronic suspension control?
Can the sport suspension settings be made even stiffer?
What is the deal with Nitrous? I always see it on japanesse imports, is it a practical upgrade for an E55?
I'm also think of getting these Lorinser front fenders, I would not get the side skirts or rest of the kit.
What do you think of these fenders?
Old Aug 31, 2003 | 01:26 PM
Rave E55's Avatar
Here is a larger pic. Man I love those slots!!
Old Aug 31, 2003 | 02:54 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
NOS sprayed directly on the intercooler heat exchanger would be good for some ponies. I think it is 1% power gain for every 10 degree reduction in temp. I don't know if I'd do a direct injection dry NOS system but there is probably no reason you couldn't get one of their wet systems that will piggyback on the stock injectors. You could pick up another few hundred ponies with a good NOS wet system.
Have you met someone quicker on the street than your 211 E55? The only quicker 4 door car out there is the S600. New tires and a chip upgrade will get you in the mid 11's in the 1/4. The new 211's are running low 12's at the track, right?
Old Aug 31, 2003 | 05:20 PM
AmgBoy's Avatar
Rave E55- I think that Renntech is a very good company and you can't go wrong by doing their chip and pulley upgrade. Evosport is also a very good company and you can't go wrong with them either. I think by getting a pulley and chip upgrade, and swapping tires (what tires come stock with E55?) your car will be absolutely unbeleivable!! I would suggest not going with NOS as I have heard some horror stories about it. One slip-up and you can be dead!! A board member (can't remember his name) had his car lowered by having the dealer tweak his ECU. The drop looks great and he says the car handles much better now.
My vote goes for upgraded tires, chip and pulley upgrade, and ECU lowering, you will be a monster then!!
Old Aug 31, 2003 | 05:36 PM
Rave E55's Avatar
Thanks,
I already changed the rims and tires, I have 19's with 285's in the rear.
I'm leaning towards the Renntech mods, I just want to see what EVO comes up with.
Old Aug 31, 2003 | 07:50 PM
dd_kota's Avatar
02 c32, 03 e55
im in on some mods but $5,000 for 40 hp through renntech seems a bit steep. on my c32 i had vadim and those guys at evosport were on that board all the time. inever see them post here. i wish they would update more. powerchip has a chip for 1200 that gets you to 489ish with a chip alone.
Old Sep 1, 2003 | 12:23 AM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
I'd suggest going with RENNtech.
Old Sep 1, 2003 | 02:02 PM
BlownV8's Avatar
I've been told by people who have dynoed stock E55's back to back on the same dyno as a new SL55 that they both dyno with the exact same hp. The new E55's have the same power as the SL55's even though Mercedes rates the SL55's higher. I'd bet it is a marketing ploy to sell more SL55's? I guess they want the SL55 owners to feel superior since they had to ante up so much more money.
Don't take any tuners word for performance. Make them gurantee their performance on a dyno. Many things will actually reduce hp when they are supposed to improve hp. You don't want to go backwards when you are trying to go forward and the only way to really know if your mods worked is to take it across a DynoJet or some other reputable independent dyno shop. Once again, make them give you a written guarantee that can be tested at an independent dyno shop. If they will not give you any guarantees, take your money and walk away.
Old Sep 1, 2003 | 07:23 PM
JLBMERC's Avatar
'14 E63S Brabus 850/2008 M5 Dinan S3(sold)
I went the RENNtech route---great improvement. I would recommend it.
What about exhaust mods? The options from range from a full exhaust change to just changing the mufflers(silencers). I am leaning toward just changing out the mufflers--the stock exhuast system is not bad---and an entirely new exhaust system is several thousand dollars--for at most 15-20 horses.
Old Sep 1, 2003 | 08:23 PM
dd_kota's Avatar
02 c32, 03 e55
did you go the 25 or 40 hp route. did you get before and after dynos? what was your price. tia!
Old Sep 1, 2003 | 10:26 PM
JLBMERC's Avatar
Check out a prior thread about RENNtech mods--has more detail. I went the ECU and Pulley route. Was not able to do a dyno--see prior threads about this as well---however,--I saw some dyno reports on SL55's(same set up) and my seat of the pants feel confirmed the improvement for me. The price was $5K plus installation. If you think this is bad--check out the price of Dinan mods. I have had around 1200 enjoyable miles since the mod--and it runs beautifully. I would like a little more exhaust sound---and as I said before, I am checking out what is available. Supposedly RENNtech is going some sport mufflers soon.
Old Sep 2, 2003 | 03:54 PM
NewBlack55's Avatar
BlownV8
I would also like to know who has has a couple of 211 E55's on a dyno in the US. Everyone that I know that has tried has had issues including myself. Any thoughts would be very helpful. It would seem that the US ECU has a serious issue with the Dyno.
Old Sep 2, 2003 | 07:55 PM
BlownV8's Avatar
http://www.mbautowerks.com/performan...t_project.html
Ask for Donnie.
Old Sep 3, 2003 | 11:03 AM
03E55AMG's Avatar
Porsche Twin Turbo, Supra Turbo, EVO Turbo
I Ran 12.7@113 , the temperature that day here in Orlando was around 97 degrees and 100% of humidity. I was pretty happy with the MPH considering I wasn't launching the car at all, I ran that time with the Trac on and with the regular tires. The track here locally SUCKS because they hardly prepared it right that day. I know with good weather and with some good tires the car should run deep in the 12's.
Old Sep 3, 2003 | 12:03 PM
JLBMERC's Avatar
Not a bad time given the temp, humidity and street tires, I doubt stock s600 in the same conditions would have done much better.
Old Sep 3, 2003 | 12:42 PM
BlownV8's Avatar
Ya think the E55 is faster than the S600's?
www.treynor.com/S600_Sacto_2.wmv
www.treynor.com/S600_Sacto_1.wmv
www.treynor.com/S600_Sacto_Liz.wmv
This S600 now with a Renntech chip upgrade runs regularly at 11.6-11.8 @ 118-119 in the 1/4.
www.treynor.com/BenzvsSupra.wmv
Old Sep 3, 2003 | 12:59 PM
03E55AMG's Avatar
Right..and imagine the E55 with the same mods and the car is lighter.
Old Sep 3, 2003 | 01:02 PM
JON913D's Avatar
Porsche / VW
same mods (chip & pulley) yes - but I think the S600 is making more HP. But the E55 is lighter. Hell the E55 is lighter than the SL55!
On those 11 sec runs he was using drag radials - FYI
Old Sep 3, 2003 | 01:26 PM
JLBMERC's Avatar
No, I don't think the E55 is faster---my point however, is that the 1/4 mile times would likely be much closer than 12.7 and 11.7 assuming you had a similarly modded E55 (ECU and Pulley--sports mufflers and drag radials) and similar altitude and weather.
Old Sep 3, 2003 | 01:52 PM
Rave E55's Avatar
I'm going with the Renntech ecu / pully upgrade, sending in the ecu on Monday.
Does anyone know of a good shop in the NY area to install the pully?
The jury is still out on the Lorinser fenders, come on guy's give me your opinion.
Old Sep 3, 2003 | 02:54 PM
JON913D's Avatar
Porsche / VW
I am not a fan of the Lorinser fenders.
edit: nevermind - that was a different company :o
Old Sep 3, 2003 | 11:16 PM
BlownV8's Avatar
"Right..and imagine the E55 with the same mods and the car is lighter."
O.K. That S600 has a chip upgrade. Get a new chip in an E55 and it still will not touch that car. Get a chip and a pulley - still will not beat that S600 in a drag race.
The S600's stats on street tires:
With RENNtech ECU and 275/40-18 Potenza S02A rear tires: 522 RWHP, 660 RWTQ, 11.99 @ 117.0
Here are the renntech chip and pulley upgrades on an SL55:
http://www.mbautowerks.com/performance/00010/00010.html
The E55 with mods would still be almost 80 RWHP and 171.9 RWTQ less than the S600. The torque and horspower difference is huge even with the weight difference. I'm a big fan of the E55 too but the S600 twin turbo is king of the Mercedes line in drag racing. Twisties, well, that is a different story.
Old Sep 4, 2003 | 06:57 AM
Ted Baldwin's Avatar
300ce
.............I am glad someone brought up the issue. I have been researching the S600 since someone here locally ordered one. Initially, I was wondering why he would do that instead of buying S55. It turns out the actual fastest production MB may not be Sl55 or E55 but S600. Unfortunately, there are not too many of them around to test. I believe car and Driver tested S600 vs BMW 12 cylinder counterpart. The stock S600 did a 0-60 in 4.3 secs. Of course at twice the price of the E55, I'll still go with an E55.
Ted
Old Sep 4, 2003 | 09:38 AM
03E55AMG's Avatar
I don't know about that, as far I know and I asked Treynor he was on race gas, I know Ill put race gas in my E55 right now and Ill run 115-116 traps NO PROBLEM in this heat humidity of FL. Now with the chip from Renntech and the pulley with the filter forget it, I know the car will be knocking if not running in the 119-121 traps easy.
Old Sep 4, 2003 | 10:38 AM
JLBMERC's Avatar
I love watching those videos---that S600 is damn fast---truly the ultimate sleeper. Sooner or later, someone on this board is going to run a modded E55--in cool dry air---like nighttime in Sacramento---and we will see
