Car went in limp mode today.
Old Jun 16, 2013 | 03:25 PM
ES EF ED's Avatar
CTS-V ///
AGAIN! How often/common does this occur? I just had this problem back in Nov 2012 and had these done to it new TCU , new valve body ,new filter , transmission fluid. I only put 1200 miles on it and today was on the freeway and the car just went in neutral so I pulled over, restarted the car and put it in drive but won't go past 3rd gear.
Old Jun 16, 2013 | 04:49 PM
berti_00's Avatar
2016 Cls63s AMG
check around your throttle body if the rubber seal is maybe stuck or something.. happen to me and it went on limp mode, the butterfly was catching the rubber hose :/
Old Jun 16, 2013 | 06:02 PM
Hulk's Avatar
A Merc
Is it throwing a cel?
Old Jun 16, 2013 | 06:09 PM
ES EF ED's Avatar
CTS-V ///
I'll check the throttle body when I get back, no CEL.
Old Jun 16, 2013 | 06:50 PM
Hulk's Avatar
A Merc
If no cel then it can be your tcu
When did you tune it?
Old Jun 16, 2013 | 07:17 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you should connect the car to das and read the transmission fault code.
Old Jun 16, 2013 | 11:20 PM
ES EF ED's Avatar
CTS-V ///
Could it be a bad IC pump, it's still the original pump.
Old Jun 17, 2013 | 07:26 AM
Ronan Mc Cabe's Avatar
Gone but not Forgotten 2006 E55 Renntech
I had a bad IC pump and it only shut down the SC, no limp mode.
Old Jun 17, 2013 | 07:46 AM
Hulk's Avatar
A Merc
Correct and since the car will not get out of 3rd this is a trans issue
Like shardul said pull the codes from star might be your conductor plate
Old Jun 19, 2013 | 01:52 AM
ES EF ED's Avatar
CTS-V ///
Thanks for all the replies everyone! Took it in today and they said they'll check it out and 'there won't be a charge if the problem is related to the work they did'
This is what they did when I took it in back in November 2012
Looking/reading some old threads, what happen to this fellow member is EXACTLY what happen to me last Sunday.
https://mbworld.org/forums/w211-amg/...late-died.html
Old Jun 19, 2013 | 04:49 AM
sloanbj's Avatar
'72 Fleedwoot
Could be time for a new transmission. Do you drive it hard?
Old Jun 19, 2013 | 06:40 PM
ES EF ED's Avatar
CTS-V ///
Don't drive it hard at all.
Old Jun 19, 2013 | 08:40 PM
berti_00's Avatar
2016 Cls63s AMG
Even if you drive it hard,.aren't these transmissions supposed to be.strong
Old Jun 28, 2013 | 11:36 AM
ES EF ED's Avatar
CTS-V ///
Just heard back from the shop and they told me 'everything is pointing towards a bad transmission, were taking it to another specialist to get a 2nd opinion'. I'm not sure if I believe them or not.
Old Jun 28, 2013 | 09:18 PM
ES EF ED's Avatar
CTS-V ///
Now they just told me 'no codes are coming up'.
