Lightweight beehive valve springs for your M113K Mercedes
If you could give me your specs, seat pressure mostly that would be great.
On a side note what a pain in the *** to cut those spring cups.
its mike you have the thin cups and the deeper spring seat casting in the heads.
At 1.47 I was at 83-85 or so. The ramp on the springs is higher than stock and you end up at the numbers he posted earlier for open. So the open and closed pressures are one set of data but the spring tension ramp is also different then then stock. Lucky we have rollers.
With all this effort I hope it works correctly LOL
Oh and no..going to use my original heads, the N/A heads are to thin to port and a couple other things so was told by two head porters that specifically do these not to bother and stick with M113K heads.
I HOPE SO TOO. We might want to think about consistent high ZDDP to stave off any additional wear from the higher pressures. Could mean nothing.
Maybe Chris can chime in and post some success story's for rpm gains with stock cams as well.
New about Bee Hive springs years ago but never really looked into them. Used to show these videos in an Automotive class I used to teach.
I'd like to replace my NA springs with something stiffer (a decrease in mass would also be nice). The Comp 26123 springs mentioned in this thread are for a boosted application, would I be better off using Comp 26113 or M113K springs?
26123 has a spring rate of 324lbs/in. 26113 has a spring rate of 191 lbs/in. Installed height and coil bind are also different.
https://www.jegs.com/i/COMP-Cams/249/26123-16/10002/-1
https://www.jegs.com/i/COMP-Cams/249/26113-16/10002/-1
My springs go in for December when weather gets colder and car is off the road for more updates.
I don't want to run stiffer springs than is necessary. Would you be able to provide numbers for na and k springs?
