Dents on corners of sunroof...
I'm just not sure how exactly this would happen, but I'm concerned that I may have been the cause of this.
Theory - I like driving with the sunroof tipped forward. Do you think that if I jacked up the corner of the car with the sunroof forward, it would have pushed on the edge of the roof?
Either way... bummed..
Or someone got pissed and hit the top of your car or sat on it and dented it. Hopefully someone has another idea, but all the opposite corner sunroof dents I've seen like that are bent chassis related. Fingers crossed it is something less substantial then that.
I actually hit a big bump/concrete chunk last month with the drivers side front at about 35-40mph. Ripped off my lip, broke the front bumper and put a bend in a wheel. I'd really be surprised if it were frame damage because my tire didn't even blow, and I had an MB tech inspect the car and he said the *suspension* looked good... but who knows...
Right now the car has been tracking VERY slightly to the left, but I figured after the inspection and all it just needed to have the alignment tweaked. It was at the body shop getting an e63 bumper painted and installed to replace the broken e55 one.
I'm the 2nd owner and the car has a clean title. I really hope it's not what you suggest, but I dropped it back off at the body shop today again for further inspection. Just called him to see if he can see any further damage under the bumper or front panels.
I just googled around the body shop, and apparently there's a "frame" shop right next door (assuming it's car frames). I'm going to call them first thing in the morning to see if maybe they can pull it over there and have them check it on the rack.
Your bodyshop should have repaired that before giving you the car back. Also, I woulfd wamt that car put on the frame rack and measured to make sure the chasis is all within factory specs. The same with the alignment.
Good luck
I still don't know exactly why these dents would suddenly appear, but they seem to think that someone jumped up on the roof of the sunroof of the car for some reason. I can gaurantee it's never happened from inside the car, but he says a lot of time some idiot will jump up on the car while it's stopped for a picture or something, and do this.
Either way, ~$500 out of pocket to fix the roof. Good times. I was thinking of doing a gloss carbon overlay on it to just mask the dent, but I think I'll go out and get it painted the factory color. Also considered gloss black paint, but it might just look weird on an obsidian black car.
Do you have pictures of the car prior to the collision? You can forward those to your adjuster and it should get covered.... if you went through insurance for the repairs.
Good luck and keep us posted.
