First AMG What A Disappointment
good luck, hope everything works in your favor and dont pay 2500 for plugs and injector thats a rip off
I hope everything works out for you and have faith that your car is indeed a beast once these issues gets worked out
Even at my small dealership, I wont let a customer buy an out of warranty car without talking to a wrench about that car. No confirmation of that, then no sale.
And yes, $2500 for plugs and injectors..... Might be a good indicator to look elsewhere...
Looks like they are prepping you to be bent over.
Hydro locked? From fuel? That's ****ing laughable. Tell them to get the hell away from your car and have it towed somewhere else. Hell, I'm no tech and only do simple stuff on my cars so I craiglisted a ASE tech in my area who charges less than 1/2 what my reg indy shop charges and is quite competent and trustworthy. All it takes is a little effort.
05-06 e55's are more reliable and much cheaper to fix, that is if your going to dump it and move on. You may be able to sell it as is to a forum member.
Another bad one is a car with hood/cowl seals that allow water to pour on the intake manifold. If the injector oring is bad, water can get past it into the cylinder and the same problem with the fuel occurs.
Do a borescope or compression test to verify.
Dealer will always try to sell you a bigger piece of the pie. I wouldn't take the chance on a AMG.
