wtb: clk 320 drag wheels
Old Aug 1, 2013 | 09:28 PM
2319's Avatar
2005 E55
I need some drag wheels!
Old Aug 1, 2013 | 10:17 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
If you go that route you will also need to buy the bolt on spacers since the wheels won't clear the brakes and also buy another set of lug nuts for each wheel. So if you didn't know it isn't as simple as buying those wheels.
Kinda sucks since you have to take your wheels off, bolt on the spacer and then bolt on the wheel, then again unbolt the wheel then unbolt the spacer then bolt on your regular wheel when done.
That is what was nice about the CCW drag setup, unbolt your normal wheel, bolt the ccw drag setup right in place and go and look good doing it
Old Aug 1, 2013 | 11:12 PM
2319's Avatar
2005 E55
Well I would love to have them but I can't swing that kind of money right now. I would be glad to borrow them. Wheels only. I have slicks.
Old Aug 2, 2013 | 12:17 AM
RedBullJnky's Avatar
you to Hate
What kind of slicks?
Old Aug 2, 2013 | 12:39 AM
Tremek's Avatar
'17 GLS 63 AMG, '08 S65 AMG
I decided to go with 265/40/18 Mickey Thompson ET Street Radial IIs on a set of Brabus 18x9.5" knockoffs, and tomorrow will be my first day out on them. Theoretically I could also mount these on the stock wheels - I will post how things turn out for more info!
Old Aug 2, 2013 | 05:13 AM
2319's Avatar
2005 E55
ET streets bias plys 26x10.5x16.
Old Aug 2, 2013 | 06:56 AM
chawkins2001's Avatar
2006 E55 AMG
I have two sets available brotha, $275 plus ship for a pair.
Old Aug 2, 2013 | 09:17 AM
you to Hate
Nice! I never had a problem hooking up with those. Good luck!
Old Aug 2, 2013 | 12:34 PM
c32ON's Avatar
2005 E55
What is correct shank length for R12 bolts when using CLK wheels + H&R 20mm adaptors (40556654)?
Are these 25mm enough or need longer ones http://otisincla.com/index.php?route...roduct_id=1029 ?
Old Aug 2, 2013 | 05:18 PM
2319's Avatar
2005 E55
Found some 160 shipped for the pair!
Old Aug 2, 2013 | 09:41 PM
Shifter's Avatar
E55, SL63, ML550
Nice find! They have anymore ?
Old Aug 2, 2013 | 09:48 PM
2319's Avatar
2005 E55
Dunno. Found em on eBay. User name is hubcapsplus. Check with him and see. Really nice guy.
Old Aug 2, 2013 | 11:57 PM
blackbenzz's Avatar
haters crazy
What Are You Going To Run In Front?
Old Aug 4, 2013 | 11:55 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I never did that, I put the spacer on to the wheel and lined up the holes and used the the longer bolts and mounted to the hub simple as that
