New guy here 2005 e55
Old Aug 15, 2013 | 06:15 PM
sufyaanahmed's Avatar
05 e55 amg
Just picked up a silver 2005 e55 picked up the car bone stock. Second week I've had it ive done 172 mm s/c pulley and tune Alex tune. I also had the cats taken out and resonators. Car feels so much better ! More responsive and a lot more powerful. I picked up a heat exchanger today locally from eurocharge that's going in next along with kleeman headers this Monday excited to see the results. Anything else you guys recomend me doing to the car would also help. I also ordered coilovers so I don't have to worry about the air suspension. Any areas you guys think I should take a look or work on ?
Old Aug 15, 2013 | 06:24 PM
3BNick's Avatar
2006 E55
Congrats.
Picked up a heat exchanger from Eurocharged? You wouldn't happen to be in Houston, would you? We have a pretty big group here and a few of the members get together often.
Old Aug 15, 2013 | 06:34 PM
05 e55 amg
Yes I am in houston i I did my s/c pulley and tune from m power houston with Ted. I wouldn't mind meeting some of the member
Old Aug 15, 2013 | 06:35 PM
RedBullJnky's Avatar
you to Hate
Congrats! Don't forget injectors and additional cooling. And definitely something for logging.
Old Aug 15, 2013 | 06:37 PM
05 e55 amg
Thanks man ! What injectors would you recomend ? I think I got the cooling part down so far have the pump installed and heat exchanger going in on Monday.
Old Aug 15, 2013 | 06:53 PM
you to Hate
I have EC red 550 injectors. And here is my cooling mod list incase you think you have enough.
Split cooling
EC heat exchanger w/ Meziere pump
3.5gal trunk tank w/ Rule2000 pump
Cobra heat exchanger mounted under the trunk
AEM water/meth injection w/ dual nozzles
Old Aug 15, 2013 | 07:02 PM
05 e55 amg
That's a lot of cooling ill definitely look into all of it thanks man
Old Aug 15, 2013 | 07:06 PM
berti_00's Avatar
2016 Cls63s AMG
you should add the 82mm throttle body to your list too
Old Aug 15, 2013 | 07:20 PM
you to Hate
it is
But I live in 90-100+ degree weather daily. I have to keep it cool.
Old Aug 15, 2013 | 07:21 PM
05 e55 amg
^ ill look into those cooling mods houston is hot as well
Old Aug 16, 2013 | 07:20 AM
BlueML99's Avatar
'99 ML320, '06 E55
Split cooling
So bosch, mezzaire or johnson ? Which is the best and y? No clear info from my search, thanx in advance bro
Old Aug 16, 2013 | 11:01 AM
berti_00's Avatar
2016 Cls63s AMG
mezzaire is more heavy duty and it requires to make a special bracket to have it installed, it is alot more powerful but its also alot more expensive.. most everyone uses Johnson pump that seems to be working perfectly fine too.
Old Aug 16, 2013 | 11:58 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I'm installing the Bosch 010 for two reasons.
1) It's plug and play -no modifications or splicing required
2) https://mbworld.org/forums/w211-amg/...-vs-wp136.html
Old Aug 16, 2013 | 12:24 PM
you to Hate
Bosch 010 pump is perfect for just a HE and pump upgrade. But I have a lot more fluid to push than most. That's why I go with the Meziere / Rule2000 combo. Remember, I'm running 2 HEs and a trunk tank. I need the stronger flow.
