Going to the bottle (Chawkins)
PLATINUM SPONSOR
Nice, looks like a starship ready for battle!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
So far these are the results on the smallest jets which are .026 nitrous/ .014 fuel with pressure at 900psi on the bottle. Spraying from 3500rpms-6100rpms.
Dyno Dynamics Dyno
Motor 522rwhp/670rwtq
Sprayed 564rwhp/710rwtq
Mixture is pretty lean right now so it will be richened up and see where I land. Back to back runs resulted in iats sitting steady at 90*.
Dyno Dynamics Dyno
#35
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Our Dyno reads 15% lower than most dynojets for comparisons sake, you can do the math. We still have a couple more things to button up though
#39
The track required a cage if you went faster than 11.90, so I did not go. Heard it was slick as hell too. Nitrous was coming in and out too, so went through the system on the car again.
#40
2003 porsche 996 turbo
craig carolina dragway in jackson s.c is open until dec. actually they have a 7pm to 11pm test and tune on dec 26 if you need a track. beech bend is open every sat in nov for t&t cage after 10.5 . d/a last week was 325!
#41
Thanks brotha
I will probably just do two track events this winter, try to get a t&t in before now and MIR. Then the mother of them all, MIR on Nov16.
#42
Just out of curiosity... Is it safe to spray pre-blower? I would think to start, compressing fuel/ nitrous mix could turn bad and also...wouldnt you run the risk of excessive wear on the blower internals? Im asking more for my own knowledge because I dont know.
#43
#45
05 White Pano E55, Cadillac CTS-V
Craig how far are you from South Georgia Motorsports Park? I think this is also known as Cecil? Everyone I know calls it SGMP though. It is just over 2 hours from me but I want to go there at some point to make some runs. Everyone who goes to Gainesville (just over 1 hour from me) says they would much rather go to SGMP because the track prep is always good and then the weather gets better up there too (colder).
I want to take my V up there and try and crack a 1.5x 60ft and run a low 10 full weight on pump gas. I don't know what kind of schedule they have if they shut down for a certain part of the year or not though but it would be cool to meet up some day there if you ever go there down the road.
#49
My little V6 is loving the 125 shot, so I think you'll be good to go with a lot more if you decide to step it up. I could feel a 75 shot, but anything smaller was not very noticeable. Good luck and enjoy the extra power.
Let me know if you find the gear changes a little sluggish, like in the datalog below. Note the boost drops to 0.9 psi on a shift.
![](http://www.crossfireforum.org/forum/attachments/racing/29792d1382836262-hit-1-4-today-new-personal-best-everything-shut-down-2.jpg)
#50
Fellas,
Doing a lot of digging. Tick tack info on Nitro, the technology has evolved, and I BELIEVE it is viewed as less risky (do I dare type "safe")...
I am on a quest for lower IAT's. Please provide thoughts...
Option #1 is Meth. Some tuners (a very highly respected one) "no like"...
Option #2 is Nitros. A highly respected tuner is OK with Nitros is very small doses (35 to 50 wet shot and won't require a re-tune).
The kit and set-up in this thread appears to be "big production" with a bunch of gauges in the dash mounted to monitor vitals and avoid the car going "BOOM", the bottle is in the back seat, references to different jet sizes and Nitros/Fuel mixtures, there is a fuel rail in the heat exchanger (which I no longer have), blah, blah, blah...
Can anyone weigh in if it is possible to do a simple install a a 35 shot?
Hopefully this simple; Bottle in the trunk with a single (or a few) lines spraying into (for example) the TB or S/C.
I would do a 10 shot if it would keep my IAT's down!
Thanks,
TK
Thanks,
TK
