Going to the bottle (Chawkins)
Old Sep 11, 2013 | 11:18 AM
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Wink Going to the bottle (Chawkins)
We are doing a small WET Shot on the double nickel,and will document the quick setup for you guys. Since I already have alot of the gear already on my car, we decided to go with Dyno Tune Electronic Hardware to control the wet system.
The system will have a few fail safes such as a rpm window switch, TPS/WOT actuator,and my Innovate Wideband. After talking to a couple guys, one of which has this exact kit on his car already,and certainly will march deep into the 10's this season (he will chime in if he wants).
I went with three jet sizes just incase, I really dont want the shot to be bigger than a 75hp hit:
Nitrous/Fuel
30/15
28/14
26/14
We will be spraying pre blower into the blower inlet, with the rpm window roughly between 2500-6200rpms,and actuated at WOT or 100% throttle which will be based on voltage through the controller. The electronics are going in today,and will have the car tuned by the end of the week. I plan to play with it a little at this weekends Wannagofast 1/2 mile event.
I will keep you updated as we progress.
Did a quick comp test to make sure everything looks healthy before the squeeze, and the results came back as follows:
158; 160; 163; 159
161; 160; 160; 159.5
Old Sep 11, 2013 | 11:21 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Very nice!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 11, 2013 | 11:29 AM
moosejaw's Avatar
none
Nice!
Old Sep 11, 2013 | 11:37 AM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
In for the vids
Old Sep 11, 2013 | 12:19 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Very nice! Will you leave the alcohol on it also?
Old Sep 11, 2013 | 01:27 PM
Yes, but if it interferes with the mixture to much, we will shut it off.
Old Sep 11, 2013 | 03:19 PM
Benz-O-Rama's Avatar
It's D/A in a bottle!
Go get em. Oh, don't forget to purge. Unless, of course, you're racing for Pesos in Mexico. In that case, purge it through the motor.
Old Sep 11, 2013 | 03:38 PM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Never seen very good result spraying through the blower. Individual port nozzles as close to the intake valve as possible is much safer in terms of distribution. It seems the blower sheers the mixture to much and causes fuel puddling. Just my opinion.
Hope yours works well for you though. Please keep us posted.
Old Sep 11, 2013 | 06:29 PM
320 dreamer's Avatar
2003 porsche 996 turbo
messing with the car 3 days before clayton? ill bring an extra chair so you can watch the races with me!! leave it be and drag race that sucka!!
Old Sep 11, 2013 | 07:40 PM
black06c230's Avatar
mgLipGD
Crazyman!!!
Old Sep 11, 2013 | 07:53 PM
chawkins2001's Avatar
2006 E55 AMG
Old Sep 11, 2013 | 09:31 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Looking forward to seeing your beast run again, you might win the fastest 4 door!
Old Sep 11, 2013 | 11:33 PM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
Look up Brian while there. He just put a nitrous kit on his CTSV too and plans to spray. He seems like a pretty cool guy.
http://www.ctsvowners.com/forum/show...ht=wannagofast
Old Sep 12, 2013 | 09:28 AM
RedBullJnky's Avatar
you to Hate
: cheers:
Old Sep 12, 2013 | 09:34 AM
Old Sep 15, 2013 | 02:23 PM
2006 E55 AMG
Going to purge into the Heat Exchanger with the nitrous ring:
I installed the nozzle into the Y pipe aiming at the throttle body:
Solenoid for the nitrous:
Solenoid for the fuel and pulling the fuel off our fuel pressure gauge port:
Controller for the window and tps parameters:
Arm switches:
The meat behind it all:
Old Sep 15, 2013 | 02:37 PM
MAN55LE's Avatar
04 E55 AMG
WOW now test that beast
Old Sep 15, 2013 | 02:53 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
So how did the 1/2 mile go? Get any runs against the V that was out there that was also spraying? 4 door vs 4 door challenge.
Old Sep 15, 2013 | 03:04 PM
S2K750's Avatar
Daily 06 E55, Fun 12 GSXR750, Racing John Deere D110
Hella powa!
Old Sep 15, 2013 | 03:55 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Just a thought, but when you pull fuel from the pressure gauge port to feed your setup will you not in effect reduce the fuel flow/pressure and cause an instability to the nearby injectors?
Old Sep 15, 2013 | 06:00 PM
Solo Man's Avatar
E55 AMG
Love the setup Craig!
Old Sep 16, 2013 | 09:30 AM
2006 E55 AMG
With my fuel setup right now which is dual 340lph pumps, and 1000cc injectors along with the looped rail, it should not be a concern. I will only be running a very small shot. Now if I was running a two stage setup with multipple nozzles, then I would not have done it this way.
Old Sep 16, 2013 | 07:36 PM
schino's Avatar
2005 E55, 11 second truck, ducati streetfighter 1098
looks like you got your nitrous jets right but just so others know, i didnt see it mentioned, you need to jet for about half of what you really want for an outcome.
while direct port works good, it doesnt work good on low hp shots because of how small the jets need to be. chawkins runs the risk as is of clogging his fuel jets let alone if he were to flow the same amount out of 8 jets total instead of 1.
good luck to you sir, im looking forward to the outcome
Old Sep 16, 2013 | 07:39 PM
BenzoBoi's Avatar
Super Moderator
W221
Just when you thought you were fast enough. Just have to go and raise the bar again... JK JK my friend!
Old Oct 24, 2013 | 03:47 PM
2006 E55 AMG
