E55 & E65 Light Weight Two Piece Rotors from RacingBrake
Old Sep 26, 2013 | 07:06 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
E430/E55 (W210)
Front: https://www.racingbrake.com/ProductD...oductCode=2284
Rear: http://www.racingbrake.com/Two-piece...EAR-p/2285.htm
E55 (W211)
Front: http://www.racingbrake.com/Two-piece...ONT-p/2141.htm
Rear: http://www.racingbrake.com/Two-piece...EAR-p/2188.htm
E63 (W212)
Old Sep 27, 2013 | 12:13 AM
cij911's Avatar
one car at a time
RB - Any idea why MB chose to cross drill vs. slotted (like your design) ? Porsche and others do the same (cross drilled)...
Old Sep 27, 2013 | 02:10 PM
CLS550
I believe it's for the look just to differentiate with the regular plain finish surface.
More performance oriented drivers prefer straight (surface) slots as the drill holes are prone to crack.
RB rotors come with open slots - a patent design that both street and track drives can agree to be the optimal disc finishes with both look and performance.
You can click below link and learn more about the pro/con on various finishes.
http://www.racingbrake.com/v/main/two_piece_compare.asp
Old Sep 27, 2013 | 03:19 PM
AMGPilot's Avatar
2004 E55
How much for just the friction rings?
Thanks!
Old Sep 27, 2013 | 03:49 PM
CLS550
You can scroll the screen down and click the replacement ring P/N, it will lead you to the needed ring with details.
Front Ring $752.66/pair: http://www.racingbrake.com/C63-AMG-F...405-01-381.htm
Rear Ring $626.31/pair: http://www.racingbrake.com/C63-AMG-R...308-03-381.htm
Old Sep 27, 2013 | 04:44 PM
cm60k's Avatar
Awesome,,
Are those Rings pattern match the OEM Hats....?
ZAYED,,
Old Sep 27, 2013 | 05:20 PM
CLS550
Our rotor design is of center mount vs. stock's surface mount, so they are not interchangeable.
We only make surface mount replacement OE discs for EVO 8/9 and 10, and GT-R due to more demand for track applications, however more serious tracking drivers still prefer RB's center mount design for it can admit cooling air both from outboard and inboard.
Old Sep 27, 2013 | 07:26 PM
cm60k's Avatar
Thankss....
ZAYED,,
Old Apr 10, 2014 | 05:28 PM
CLS550
Originally Posted by cm60k
Thankss....
ZAYED,,
No worries.
Old Apr 11, 2014 | 01:19 PM
baldmike73's Avatar
may want to include for E63 W211 too -
Old Apr 11, 2014 | 01:37 PM
Denroll's Avatar
'06 E55
Yep, there's only one E65; pretty small market, lol
Old Apr 11, 2014 | 02:13 PM
CLS550
Here they are:
Old May 9, 2014 | 06:41 PM
CLS550
We are now offering Free Shipping to the lower 48 states using coupon code
MBW-SHIP
-Valid till the end of June.
Old May 15, 2014 | 10:19 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
I have had the fronts on for 38k and very pleased. Wear rate similar to OEM. Using OEM pads.
Old May 15, 2014 | 10:21 AM
berti_00's Avatar
2016 Cls63s AMG
can someone explain to why the e63 rotors are so expensive compared to the e55? or the c63? i've noticed the e63 guys are dropping the c63 rotors on them as they are a direct fit and half the cost if not less.
Old May 15, 2014 | 10:31 AM
Two piece floating rotors with aluminum hats vs a single piece.
$650 vs $125 or there abouts.
Old May 19, 2014 | 06:54 PM
CLS550
Thank you for your input!
Old May 19, 2014 | 08:55 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Are slotted rotors available?
Old May 20, 2014 | 11:36 AM
CLS550
For which model?
Old May 23, 2014 | 08:37 PM
statepkt's Avatar
2007 E63
Still need a quote for just the rotors and no pads
Old May 25, 2014 | 04:05 AM
Originally Posted by RacingBrake
For which model?
w211 E55
Old May 27, 2014 | 11:44 AM
CLS550
w211 E55
Unfortunately we do not have a slotted option,
we only have open slot surfaces available for the E55 w211
Old May 28, 2014 | 10:58 AM
moosejaw's Avatar
none
can i get a pm for rotors only pls?
Old May 28, 2014 | 12:16 PM
CLS550
Brake pads are included for free to ensure compatibility with the rotors and brake pads.
We cannot exclude the brake pads from the package,
sorry about that.
