Changing Front suspension parts
Old Oct 8, 2013 | 03:47 PM
serge718's Avatar
2007 E63
I am ready to change most of my front suspension part on my E63 with 99K on it
Left And Right Lower Control Arms With Ball Joints & Bushings
Left And Right Ball Joints
Left And Right THRUST Control Arm
Any pointers on what will be most difficult part of the work ?
I got ball joint press and bought the ball joint separator. I will be using this instructions - https://mbworld.org/forums/e-class-w...oint-w211.html
Thank you in advance,
Serge
Old Oct 9, 2013 | 12:38 AM
Lawrence1's Avatar
2011 G55 + others
What symptoms are you having leading you to replace all the parts listed?
Old Oct 9, 2013 | 04:57 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I had to grind the tips off my separator fork so it wouldn't dent the backing plate. Caliper bolts are TIGHT! and awkward.
Old Oct 9, 2013 | 08:52 AM
serge718's Avatar
2007 E63
Symptoms that I want to fix are :
1- wheel vibration from 55mph to 85mph+ ( alignment was done but didn't help much)
2- squeaking/creaking sound going over uneven surface or bumps
3- car has 99K and some front suspension parts on the car are original
4- most rubber bushings are very dry and even lubrication won't help when temp get colder ( i live in NY )
Old Oct 9, 2013 | 09:47 AM
FinanceMike's Avatar
CLS55
What brand of parts did you go with?
Old Oct 9, 2013 | 10:04 AM
serge718's Avatar
2007 E63
Some OEM - Ball Joints the rest ebay (aftermarket) to save cost. Will report back on results next week. Doing work with weekend.
Old Oct 23, 2013 | 12:04 AM
Lawrence1's Avatar
2011 G55 + others
How did this turn out?
Old Oct 23, 2013 | 12:37 PM
Pjnash's Avatar
2005 E55
I recently changed:
Rod at Torsion bar right 211-320-3889
1 Rod at Torsion bar left 211-320-3989
2 Bearing Bushing for Torsion Bar 211-333-1914
2 Rubber For Torsion Bar 211-323-0068
1 Control arm Left 211-330-8107
1 Control arm right 211-330-8207
1 Strut Arm Left 211-330-1511
1 Strut Arm Right 211-330-1611
1 Upper Control Arm Left 211-330-0138
1 Upper Control Arm Right 211-330-0138
2 Upper Ball Joint A000-330-1007
2 Lower Ball Joint 211-330-0435
2 Camber Bolts 000-330-0018
1 Outer Tie Rod Left 211-330-2703
1 Outer Tie Rod Right 211-330-2803
2 Inner Tie Rods 230-338-0015
I went with OEM parts, what a joy the car is to drive.
Car has 103K on it, feels like a brand new car(not that I have ever owned one of those)
Old Oct 23, 2013 | 12:51 PM
MAN55LE's Avatar
04 E55 AMG
1) 55-85mph vibration can be attributed to wheel imbalance...
Old Oct 23, 2013 | 01:24 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Originally Posted by Pjnash
I recently changed:
How much did you spend on parts ?
Old Oct 23, 2013 | 05:14 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
due to sway bar bushings.... get some Wurth HHS-K and spray sway bar bushings
Old Oct 30, 2013 | 05:21 PM
yellowduc's Avatar
1995 E300
I have a '95 E300 which bottoms out on a dip in the road. Dealer replaced struts. Did nothing. I'm going back Friday, what can I ask them to look for next? Problem was they did NOT test ride it with 400 pound in the car. It only happens with my (300) weight plus a light passenger (130). One typical mechanic will never make it bottom out!
Old Oct 30, 2013 | 06:15 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
upgrade the bushing with K_Mac
did you check to see if the BJ were bad or are you just changing them because of the miles.
I have 75k and my friend at a local shop when over my car.
He said all parts were in perfect condition at 75k.
I am also in NYC.
Old Oct 30, 2013 | 06:31 PM
£ C43 £ AMG £'s Avatar
E55K AMG
I am afraid that from my own experience, using aftermarket suspension parts is not good, non original Ball joints don't last as long and their a pain to change without the correct tools, the rest is easy.
Old Oct 31, 2013 | 12:31 PM
AMG55TECH's Avatar
2004 E55, 2003 IS300
New springs...
