Its been 3 months and I still haven't figured it out. Advanced help wanted! *SOLVED*
Old Nov 4, 2013 | 02:06 PM
  #51
Quadcammer's Avatar
96 and 08 911 turbos
Originally Posted by 03'55AMG
Fuel pressure when primed is about 72 PSI, and bounces between 70 and 80 PSI when cranking. Cam sensor plug was in all the way also.
plugs wet with fuel or no?
Old Nov 4, 2013 | 02:12 PM
  #52
Critter's Avatar
07 E63 + 07 CLK63CAB
Do you have a code reader that will register throttle position %, if so hook up to the obd port , switch to live readout and monitor the % position when key on and the while cranking. Fuel pressure is good, now we need spark and the electronics to control, ie crank sensor, cam sensor, throttle sensor, you need MBtech support.
Old Nov 4, 2013 | 03:23 PM
  #53
03'55AMG's Avatar
AMG
Got my solus ultra and STAR from work so I will check plugs for fuel and data log the TPS and report back
Old Nov 4, 2013 | 04:31 PM
  #54
03'55AMG's Avatar
AMG
Just got done logging. Current codes again:
Fuel pressure:
Key on Engine off:
Here is after attempting to start it. Even after it stopped cranking, the engine remained at 105% load... Weird..
I also had an ASE Master tech look it over, and he says he would unbolt the exhaust or check for back pressure in the exhaust next. Let me know if there is anything else I can do to help you guys help me. Honestly, I would be screwed without this forum and the people on it, so thank you to everyone helping thus far!!
Old Nov 4, 2013 | 04:36 PM
  #55
AMG55TECH's Avatar
2004 E55, 2003 IS300
does your supercharger spin freely? (the section directly after the clutch/ pulley). I watched your last cranking video and it soulds like its trying to start but it almsot sounds like something is really dragging down when cranking and holding back the engine. Ive seen a few cases where something inside the supercharger siezed and caused the engine to stall and not restart until the supercharger belt was removed.
Old Nov 4, 2013 | 04:42 PM
  #56
03'55AMG's Avatar
AMG
SC spins freely, nothing hindering it whatsoever
Old Nov 4, 2013 | 04:45 PM
  #57
03'55AMG's Avatar
AMG
I showed the video to the mechanic as well and he said that could be from it running and the cats being plugged preventing it to idle
Old Nov 4, 2013 | 04:47 PM
  #58
AMG55TECH's Avatar
There would have to be something physically dropped in the exhaust or shoved in there causing a complete blockage to be stoping the engine from starting at all. I'm not saying it's not possible... But very very unlikely... Unless you think someone is nasty enough to play that kind of prank on you
Old Nov 4, 2013 | 04:49 PM
  #59
03'55AMG's Avatar
AMG
Car is always in the garage under video surveillance, and nothing but me has been around it unless I was present. So I doubt it's packed with something..
Old Nov 4, 2013 | 05:04 PM
  #60
Critter's Avatar
Why the 105% engine loading for starters, the other is with a plugged exhaust the car should still start when there is minimal pressure then stall out as back pressure increases. Other point is will the car run when the gas pedal is pushed down during start and short run episode?
Old Nov 4, 2013 | 05:09 PM
  #61
03'55AMG's Avatar
AMG
Tried starting while holding the gas pedal down and it cranked normally but no start, or attempt to start.
Old Nov 4, 2013 | 05:15 PM
  #62
Critter's Avatar
Sorry did not mean "push down" was referring to will the car when it tries to start give a little throttle to assist.
  #63
E55Greasemonkey's Avatar
This place is a joke.
What do the plugs look
like? Is the gas fresh
Old Nov 4, 2013 | 05:21 PM
  #64
  #65
03'55AMG's Avatar
AMG
Just put some fresh gas in to mix with the old. Also put in some octane booster. Plugs are black and soaked in fuel.
Old Nov 4, 2013 | 05:24 PM
  #66
It will never start with fouled plugs.
Old Nov 4, 2013 | 05:26 PM
  #67
03'55AMG's Avatar
AMG
I will pull all sixteen and have them sandblasted. These plugs have less than 10 miles on them...
Old Nov 4, 2013 | 05:45 PM
  #68
Critter's Avatar
Would not sand blast plugs, if any sand stay up inside of the plugs then it will get into the engine. Leave plugs out overnight, use a propane torch to just burn off, (use for seconds only) any fuel left or if feeling dangerous put them in the oven set at 150-200 degrees for 20 minutes. These plugs look really flooded or deposits inside of the engine have been washed and deposited on them. If you still have the old plugs put them back in and try a restart. Did you happen to get a throttle position % key on and when you depress the throttle does it change the %. Still think this is related, AMG55tech where are you!
Old Nov 4, 2013 | 07:37 PM
  #69
03'55AMG's Avatar
AMG
Can anyone post the TB relearn procedure? Shardul told me it one but I forgot it
Old Nov 4, 2013 | 08:36 PM
  #70
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
If your screen shots were taken while cranking the engine you have no crank signal.
Old Nov 4, 2013 | 09:49 PM
  #71
03'55AMG's Avatar
AMG
They were taken after, not during.
Old Nov 4, 2013 | 11:04 PM
  #72
03'55AMG's Avatar
AMG
All plugs are out and will be cleaned tomorrow. Here's a few pics of the plugs with the fuel dried off. Sure is a lot of junk on them considering how many miles are on them...
Old Nov 4, 2013 | 11:10 PM
  #73
Critter's Avatar
Do you self a favour and just put new plugs into the engine. Those plugs look like they were used in a 72 vega that used 3 quarts of oil a day. This time go for NGK iridium as apparently your car does not like Bosch. Are these plugs of a colder value than stock?
Old Nov 4, 2013 | 11:12 PM
  #74
03'55AMG's Avatar
AMG
These plugs were stock heat range. Can you provide the part number to the stock issue ngk's?
Old Nov 4, 2013 | 11:17 PM
  #75
Critter's Avatar
Look up Sparkplugs.com for the proper plugs for your car. I have 2 63's so not familiar with what your 55 would take. \But 10 miles that is terrible. when you get this car running you need to go on a long drive down the highway to clean the engine out. You are getting close now.
