Smaller 84mm SC Pulley Black Grease?
Old Oct 26, 2013 | 12:11 PM
kingnash's Avatar
03 SL55
Hi, installed the 84mm smaller sc pulley. Has about 500 miles on it. Noticed this black grease that builds up. It feels kinda slippery and wet, see attached pictures. Was told it was just dirt, but a second opinion wouldn't hurt. Gets annoying that i have to clean it every week, given that i only drive the b*tch twice a week. Side note- the dirt/dust that builds up on my tensioner and idler pulleys actually look like dirt and are not greasy looking/feeling.
1-Did anyone else notice this on their smaller 84mm sc pulley?
2- What is it?
3- Is it normal?
4- Should i ask for a new replacement from my vendor?
Thanks for your time guys...
Attached Thumbnails Smaller 84mm SC Pulley Black Grease?-20131017_172227.jpg   Smaller 84mm SC Pulley Black Grease?-20131017_172320.jpg   Smaller 84mm SC Pulley Black Grease?-20131017_172328.jpg   Smaller 84mm SC Pulley Black Grease?-20131017_172606.jpg
Old Oct 26, 2013 | 12:53 PM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I have similar miles on mine and do not have any grease build up like that.
Initially, i saw a little bit of oil at the bottom of the bearing, but i think that was just the machine oil I used on the inner bearing wall when i installed it.
Did you use grease when you put the pulley on?
Old Oct 26, 2013 | 12:56 PM
kingnash's Avatar
03 SL55
ya, i used wd-40 to slide the new pulley on.
Old Oct 26, 2013 | 01:03 PM
Toadster's Avatar
2005 E55 AMG
leaking bearing?
Old Oct 27, 2013 | 02:08 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Seal is damaged most likely.
Old Oct 27, 2013 | 11:31 PM
kingnash's Avatar
03 SL55
So this is not normal and i should ask for a replacement??
Old Oct 27, 2013 | 11:35 PM
ArmoE55's Avatar
2006 E55
I have ~700/800 miles on my upper pulley and do not have that any grease like that.
Another vote for leaking seal / bearing.
Old Oct 28, 2013 | 12:47 PM
AMG55TECH's Avatar
2004 E55, 2003 IS300
I may be mistaken, but im pretty sure that its not necesaraly a "seal" but more of just a dust cover and more of a "grease retianer" than a seal. Im not saying that this is normal, but I wouldnt be all too alarmed about it either. after all...that pulley is spinning more than twice as fast as the crank, so on a brand new pulley, there may be a little extra grease in there thats just finding its way out. My honest opintion would be to contact the vender you got the pulley from and send them the pics and see what they say.
Old Oct 28, 2013 | 01:04 PM
novae500's Avatar
W211
AMG55TECH
Good to see a MB tech on here helping out and giving advice to us!!!!
Old Nov 2, 2013 | 01:21 PM
kingnash's Avatar
03 SL55
bump. Is anyone else experiencing this issue?
Old Nov 6, 2013 | 01:34 PM
kingnash's Avatar
03 SL55
bump. I cleaned the sc pulley, drove it, and the black greasy crap is back again. See attached pics.
Attached Thumbnails Smaller 84mm SC Pulley Black Grease?-20131101_155230.jpg   Smaller 84mm SC Pulley Black Grease?-20131101_155243.jpg   Smaller 84mm SC Pulley Black Grease?-20131101_155251.jpg
Old Nov 6, 2013 | 01:39 PM
Toadster's Avatar
2005 E55 AMG
definitely seems like the bearing is leaking - not crazy bad, but will eventually give out...
speaking of which, I need to check my blue bearing to see how its' doing after a week of driving
