MAP sensor problems?
Old 10-20-2014, 12:32 PM
  #76
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
ECS tuning got them for $43..
http://www.ecstuning.com/Search/ES1618145/ES1618145/
ZAYED,,
Old 10-20-2014, 12:42 PM
  #77
Hulk's Avatar
A Merc
Good job
Old 10-20-2014, 01:29 PM
  #78
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
ZAYED,,
ZAYED,
Thanks for the shout out!
David
Old 10-20-2014, 06:48 PM
  #79
Denroll's Avatar
'06 E55
I got my MAP sensor from O'Reilly's Auto for $19.99 + shipping.
Old 10-20-2014, 06:55 PM
  #80
Hulk's Avatar
A Merc
Same one?
Old 10-20-2014, 09:30 PM
  #81
Denroll's Avatar
'06 E55
It was a plain Bosch sensor. Some extensive google-fu showed that it cross-lists as several different MB part numbers, to include the most recent version of ours.
Old 10-20-2014, 09:38 PM
  #82
Hulk's Avatar
A Merc
What was the part number at oreilleys?
Old 10-21-2014, 12:29 AM
  #83
Denroll's Avatar
'06 E55
Bosch part number: 0261 230 191
Same part number on O'Reilly's:
http://www.oreillyauto.com/site/c/de...ord=0261230191
This is the part I am using on my car now.
Old 10-21-2014, 12:48 AM
  #84
Hulk's Avatar
A Merc
Ok thanks
Old 10-21-2014, 09:16 AM
  #85
rockthemullet's Avatar
2005 Mercedes E55 AMG
Niceee
Old 10-21-2014, 09:30 AM
  #86
Hulk's Avatar
A Merc
Advanced has it also, weird that they say it's not for our car but denroll is using it
Old 10-21-2014, 05:30 PM
  #87
cm60k's Avatar
Don't listen to them, friends here are more HELPFUL..
ZAYED,,
Old 10-21-2014, 07:15 PM
  #88
Roverron's Avatar
ML63
I would like to know if this has fixed the over boost issue.
Old 10-21-2014, 07:26 PM
  #89
Hulk's Avatar
A Merc
No, if you are over boosting this will not solve the problem
Old 10-26-2014, 01:26 AM
  #90
boki1012's Avatar
w211 e55
The best way to fix this, install 4 bar map sensor, input custom code into the ecu to read up to 4 bar, tune the car
Old 10-26-2014, 06:09 AM
  #91
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
There's more than a few parts they have for us that they say is not for our cars.
Old 10-26-2014, 06:29 AM
  #92
cm60k's Avatar
^Agreed^,
Noticed that with many sites, they said; WE ARE THE BEST & PROFESSIONAL VENDORS..!!
ZAYED,,
Old 06-13-2015, 09:30 AM
  #93
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Nobody ever listed the code it shows for map sensor
Is it P2007-8
Old 06-13-2015, 11:43 AM
  #94
Hulk's Avatar
A Merc
Yes
Old 10-05-2015, 01:53 PM
  #95
Timbershake's Avatar
2014 CLS63s AMG
WOW!! I really enjoyed reading this thread, I think someone has little man's syndrome
I'm experiencing these error codes too after installing 82mm Throttle body and 3.5" intake piping...
Old 04-12-2016, 01:48 PM
  #96
cnterline's Avatar
Any progress on this lol
Old 04-12-2016, 03:27 PM
  #97
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
after re-reading this thread.......it seems that erebus feller has a lot of bottled up teenage angst.
Old 04-12-2016, 03:31 PM
  #98
EREBUS's Avatar
Uh, with the dude with no socks are my map sensor meltdown?
I say he probably still doesn't wear socks and I used the cl600 map sensor with a map clamp. One has smelly shoes and the other doesn't go into limp mode. Unless, I have too much to drink. Oh,wait.....what?
Old 04-13-2016, 04:06 PM
  #99
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Wait, so the Bosch 0261 230 191 MAP sensor from the v12 cars fixed this hiccup issue for everyone or are you guys just living with it?
I had this code around this time last year without the leaning out part or any idle issues then it went away by itself with stock pulleys and TB.
Fast track to this year and I now have my 82mm tb on with another stock MAP sensor but same time of year and this code popped up once with a weird idle afterwards and the car hunting for 14.7afr. Taking my intake apart to check for leaks just to rule that out.
Old 04-13-2016, 05:03 PM
  #100
EREBUS's Avatar
Yes and no? Depends on how much boost you are doing. If you are hitting 14-16 psi on occasion, I have heard this map sensor delays triggering limp mode..........but still will trigger it. The key part of my comment is Map Clamp. Split Second is the company who makes it. Set the module to 4.5v and never look back.
Quick Reply: MAP sensor problems?
