M113K & M113N/A crankshaft....
jamesge (09-01-2020)
Received 1,488 Likes
This place is a joke.
Haha...that is also correct...but in the U.S. we would call this a "stroker" engine, referring to the piston stroke.
In this case it means the piston will travel further up and down, meaning the "stroke" of the piston has been changed..what this does is increase the displacement (more cc's or cu. In) without changing the bore diameter (the diameter of the pistons). This is done using a crankshaft with the rod journals further away from the centerline of the crankshaft.
Now, thinking about it, not sure if the OP was referring to the base 113 engine, or the N/A AMG 113 (as in the 210 chassis E55) vs the S/C AMG 113 in our 211 chassis. I'd have to look up the specs on that.
00 C200 & 00 C55 & 06 SLK55
Thankss for info.,
Is there a special treatment or something with M113K crankshaft & con. rod & piston, than M113 N/A...?, if so,
that could help to unleash some power to M113 N/A....!!
ZAYED,,
ZAYED,,
96 and 08 911 turbos
Regardless if the NA version is lighter or not, if you use it in a supercharged application you have to have it weight balanced to match the weight of whatever pistons and rods you're using , so it's not really a benefit. It'll cost more to balance as a matter of fact if weight has to be added.
