Exhaust system thoughts...
http://www.cobaltss.net/forums/suppo...epower-284725/
kind of like this...
Personally, I think you are better off with something that is just on or off at your control. Not something that comes on just during boost. Something like the QTP electric cut outs may be a better option.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
My exhaust system is all stock except the resonator delete. The only reason I deleted the resonator was because the car gets a more throaty/deeper sound now. I did not want to touch the secondaries and definitely not the primaries. I've never been a fan of deleting cats on any of my cars, but that's just me. On my previous E39 M5, I added an Xpipe and a loud aftermarket muffler and it was MORE than enough noise and dB without getting annoying or waking up my neighbors.
I have a set of 2012 C63 mufflers in my garage right now waiting to be installed. My setup will be resonator delete straight piped into the the C63 mufflers.
I will post a thread and my impressions when it is done. I am expecting a great deal of noise difference from the stock mufflers.
Since you have the Kleemanns and other deletions, your car will be plenty loud if you put the C63 mufflers on. In my opinion, you have to keep some sort of luxury to these cars, you have to keep that Mercedes class a bit. If not, we could all drop cutouts and be done with it. You want an exotic sound that is loud when you want it to be, and tame otherwise.
Good luck and look for my thread after the C63s go on the car.
Expensive mistakes until "right" how do you know the second time will be better?
Many more would give it a try were it not so expensive in the redo.
Really tough to know best setup- especially with so many options and valid opinions.
Stock CL550 hiding in the weeds with envy.....waiting.
Berti 00, do you possibly have a video or sound clip of your car, that would basically be the exact same exhaust setup
