Fuel smell & gas cap warning light
Some questions:
1. Could this cause a lean condition at WOT? With fuel leaking, wouldn't the drop in pressure cause any engine related issues?
2. Last I checked and the passenger side had the fuel puddling. Do I just replace the fuel filter sender assembly and call it a day?
3. What about the blinking fuel light and gas cap warning display? Will that go away after the fuel sender replacement and a battery reset?
Also any suggestions or helpful links regarding the blinking light fix would be a great help! Thanks.
It would be best to properly diagnose where the fuel is leaking from.
1) Remove the rear seat bottom
2) Remove the access panels for the fuel sending units.
3) Clean the area completely of any fuel, dirt, and debris.
4) Either fill the fuel tank full and see where the fuel is leaking from. The other option is to pressurize the system with a smoke machine, or regulated air through evap line under the hood.(at the purge valve) Spray the filter housing/fuel tank with soapy water and watch for bubbles.
Thank You, Ive done the initial check and it is leaking but just barely around the top of the fuel filter assembly on the passenger side only. Driver side where the pumps are located are nice and dry.
As recommended by shardul I will swap the green $20 gaskets and see if that takes care of it. Its not pouring out, just barely pudding when i fill the tank just on the passenger side.
Interesting… Canister shut off valve… Hmmm wonder if that is what closes the tank when its full? No idea,
Anyone know what that is??
This is the charcoal canister shut off valve, adapter harness, and seal ring. This is part of the evaporative emissions system. As pressure builds in the fuel tank they need to escape. The activated charcoal canister aids in the absorption of this. The shut off valve opens for (safe) out gassing of the otherwise sealed fuel system.
Good luck with your's. Let us know what it is when you finally figure it out.
