CLS55 mufflers on E55
Is there a noticeable difference putting CLS55 on the E55? I always thought the parts were the same.
Any advise?
C63 > E63 > CLS55 > ... > E55
Not sure where the CLS63 mufflers slot in and why the SL55/63 mufflers have never been discussed, though.
I would have def thrown a pair of CLS55 mufflers on my E55 if I would have known back then.
check out my vids
IMO c63 and cls63 sounds the same on e55
e55 with c63 mufflers and res delete
I watched your vids and YES, the CLS does sound frickin awesome.
PS- I have always though you have the absolute best looking E55 there is... Serious!
yeah I wanted to hear the sound difference which in the end, the cls63 sounded better
nice! lol
Check the 'Exhaust Sound Thread' started by Denroll sometime Sunday or Monday ... I will have my setup on there as well.
C63 Mufflers and Resonator Delete (straight piped back to the C63 cans). Stock when normal cruising/driving, loud and scary when WOT. On cold starts, it sounds BRUTAL.
Any advice would be great.
Bramage your inbox is full
Had my local motorsport shop cut out the mufflers just behind the axel. From there we tacked 3 inch pipes all the way out to the stock tips that we cut off of the old mufflers. At first we welded up a y so both tips were still functional and the droooone was obnoxious. After a little bit of thought we decided that the y was causing the drone, acting like a flute. (We test drove it with just the old pipe cut off right near the rear axle, sounded right) So, out with the welder again. This time we modified the existing tips so that the 3 inch pipe could go through the outside section of the tip only and closed off the inside section to maintain the stock look. Sounds good, especially at WOT!. Plus, we shed about 55 pounds!!!!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Im talking from the start (off muffler) to the end of the tips
Pics would be great too
The tips (from muffler to end of tip) are 1.25" longer when doing a side by side comparison. The mounting post is in a similar place, but they are bent down on the CLS55 muffler. We bent them up about 3/4" to get the muffler positioned. What I did was cut out a 1" of exhaust and pulled the entire assembly in to get the tips where I wanted them. If I did this again, I would have cut and re-welded the mounting posts.
The tips also sit 3/4" in towards the center of the car. You will need to trim the rear valance.
Sound is amazing, and as I have said before: I would not change this to the C63 units. Those are too loud for me
I was going under an Under-pass with some construction workers at the far end dicking around.. I gunned it under there and I saw all of them jump, and then stare. I had the window down and it scared me. All of us looked like:
Not much difference in just cruising around/ no drone, but very loud at WOT or even half throttle.
Love it.
