dragstrip fun over till 14
Old Dec 6, 2013 | 01:17 PM
99lightning's Avatar
99 ford lightning
The weather is looking not so great for remainder i doubt i will make the last atco rental as well. I wanted to finish up with a really good et but sometimes its the way it goes. As my power increased with addition of the longtube headers even with a new posi my 60fts have been getting worse. I have never dead hooked the car since last december before the stall convertor. Even with my best of this year 1.64 short time that was spinning. Not playing around for spring switching to quick time pros i talked to hoosier they said its way more consistant and hooks way better on a less prepped track, since it uses same compound as the full slick. Not to mention its a better softer sidewall and a few pounds lighter. I wanted to try out my fixed tune for the tcu tune now that it doesnt hit rev limiter but i guess it will have to wait. 11.59 120.13mph spinning a 1.69 800ft da. mbh headers added, 11.482 at 121.3 1.67 short time spinning in a 25mph head wind. more to come in 14
Old Dec 6, 2013 | 01:24 PM
Dr Matt's Avatar
05 CL65
At least you got to have some fun. By the time I got my CL our only Alaska track was already closed for winter. I never even got to race my CL & Lightning against each other before the Lightning sold.
Better luck next summer. Hope you get the #'s you're looking for.
Old Dec 6, 2013 | 01:29 PM
chawkins2001's Avatar
2006 E55 AMG
Yeah, it is not easy launching these cars once you get up there in HP/TQ. The hoosier qtp's are the way to go, I used them this past spring and got a 1.65 60ft at my power level on 28's.
You can always trailor down here for some action
Old Dec 6, 2013 | 02:03 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I see some 1.5xx short times in your future. If you need a little more weight transfer, you can always use the good old American made car trick and remove front sway bar or un-hook the links
Wow, never thought of Alaska having a drag strip
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 6, 2013 | 03:33 PM
99 ford lightning
yea i will unhook it i asked chawkins about it the other day i mean i drove the lightning 4 years without one and the saleen i had took it off pretty much since new. Probably unhook and tie the thing up. Thanks all car is a blast to drive.
Old Dec 6, 2013 | 06:07 PM
2006 E55 AMG
You are always welcome to come down south to drag in the winter bruh
Lets set it up after the new year.
Old Dec 6, 2013 | 06:18 PM
99 ford lightning
man i will have to hustle up some money its been a rough slow year in the paving business. that would be fun though
Old Dec 6, 2013 | 06:23 PM
RedBullJnky's Avatar
you to Hate
The fun never stops down South.
Old Dec 7, 2013 | 07:20 AM
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
When is the last rental? I know the weather is not cooperating very well for next week. The only decent weather I see is actually today and I think the high is 42 degrees...That's decent for what's coming this final week!
Old Dec 7, 2013 | 08:35 AM
99 ford lightning
friday there was suppose to be a rental. I know once the track closes the weather will be awsome after that lol thats the way it goes usually.
Old Dec 7, 2013 | 09:01 AM
60nomad's Avatar
I just called Kevin at Atco and the message says no track rentals as of now. Next Friday looks like clear weather and 40 degrees. I was there in 47 degrees and did a 1.58 60ft so that may not be the end of the world. I will wait to hear from Kevin and if he says ok then I will post on the amg forum and here and see what we can do. I have others as well that would go so we will shoot for that and I will start a thread if he says it's a go.
