Scorchie Says....
2009 C63 AMG
Scorchie Says....
That the red capped tube on top of the supercharger is the oil dipstick tube. That means we can use the Topsider to change our oil without having to go under the car! Sweet! I'm going to change it this weekend. Mobil One 5W-30. Isn't MB engineering great!
2016 GLE63s / 2016 E63s / 2002 E55
You have a W211 E55? Change your signature - it says "E55 on order". Thanks.
Why waste money if the car is under warranty? It doubt you will realize any performance gains with that oil viscosity.
2009 C63 AMG
break in oil? No 5W-30 is the oil I use on all my cars. That weight oil, I read, has the least amount of additives, almost a pure oil, and its rated for the temperature swings we have in Houston.
Upgrades are for "Show" or "Go" and 5-30 oil is neither!
Originally posted by norb
And green caliper paint does?
By the way who has Green Calipers? Anyone on these board?
2009 C63 AMG
1995 Jaguar XJS Convertible
Re: Scorchie Says....
[edited]
And there is a reason MB engineered the oil filter to be on top of the engine. Do you think that is a coincidence?
I am trying to find a pic of the W211 E55 engine. Does the supercharger uses the same engine oil from the block? I thought that the blower was a self contained unit with a separate oil system or some permanent type of lubrication or something?
2009 C63 AMG
It is about whether you need to waste you time, money and effort while the car is under warranty and using a preferred viscosity of oil.
It probably will take less time than painting the calipers or waxing my car.
hey guys....i change my oil between the MB 10000 service intervals at 5000 miles. all my MB's have drain plugs...i know the guys at the dealerships like the topsider method because they don't have to remove any of the bottom plastic panels. personally i like draining from the bottom...i figure anything that might not be normally sucked out from the topsider will drain out the bottom because of gravity..........
one question....why are you using such a light weight oil? i'm not familiar with the kompressor motors requirements but i would think a heavier weight oil might be better suited for your car and for where you live.....warmer in houston.
2009 C63 AMG
30 weight oil is approved for over 86 degree weather just like the 40, 50 and 60 weight oil. But to get that wide of a rating, they are putting additives in the oils, so I'm sticking to the MB approved weight of 5W-30 Mobil One. Although, I might use the 0W-40 when and if I find it locally.
