E55 AMG Key Wont Turn. I Was stuck in my car :(
Old Jan 22, 2014 | 11:12 PM
E55AMG05's Avatar
2005 E55 AMG
Thank god it happend in my garage. I'm in CT it's -3•f out here. So I did a lot of errands finally came home and i noticed that I parked a little to close to the garage door so I went to move the car up a little. I sat in the car THE KEY TURNED BUT THE CAR DIDENT START!!! so I removed the key and i gave it another try but this time the key it dident turn at all. It was like as like as if there was no battery. Nothing was working WTF I try to unlock the car it won't budge I tried turning the radio turning the light on NOTHING. I waited 30 sec door opened key was working and car started with normal voltage readings. What the hell it has been doing that but not often as now and this one has gotten much worse. Wth HELP PLZ
Old Jan 22, 2014 | 11:17 PM
E55AMG05's Avatar
2005 E55 AMG
I wonder if its the car battery module or if it's the EIS(car key switch) idk based on what I am explaining what can it be? Can I also add that I did my oil change and I noticed a hose hanging off from the starter idk where it connects to. It's a hose in the middle is a white plastic looking thingy and in the end of it is a hose that connects to something idk
Old Jan 23, 2014 | 08:26 AM
pimpjuice's Avatar
2003 E55 AMG
I am pretty sure the white hose is your overflow for collant or maybe its from the winshield washer lines.
being stuck in the car...while hilarious....I have no idea!
Old Jan 23, 2014 | 09:05 AM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Pictures of the hose would help.
Old Jan 23, 2014 | 09:34 AM
thumper823's Avatar
04 E55
change out the battery for the key, then check trunk battery. then i would check the IES with star.. works best with 2 keys. good luck!
Old Jan 23, 2014 | 09:46 AM
E55AMG05's Avatar
2005 E55 AMG
Yea I was stuck in the car in my garage minus 3 degrees. I woke up 4am last night turned the car on drove it around a lil and everything seems normal idk but that hose is weird idk if it can be for the coolant or windshield washer because its hanging right of where the starter is.
Old Jan 23, 2014 | 09:47 AM
E55AMG05's Avatar
2005 E55 AMG
Listen give me a DIY on posting pics here. Because for me it's impossible.
ArmoE55's Avatar
2006 E55
It might be something as simple as the battery in your key going out.
Do you have keyless go or just turn key?
Not sure on the the hose issue...
Old Jan 23, 2014 | 09:56 AM
E55AMG05's Avatar
2005 E55 AMG
You got it, first up I had the car for 3 and a half years never changed battery's on anything. Auxiliary battery was never changed by both me and the previous owner who bought the car brand new back in 2005 as for the main battery it was changed back In 2008 it has a deka brand. Does that seem far off to you in the years?
Auxiliary battery age is = 9 years old
Main battery which is deka(not mercedes brand) age is = 6 years old
Car key & battery was NEVER changed age is = 9 years old.
Old Jan 23, 2014 | 10:31 AM
thumper823's Avatar
04 E55
i havent had a issue with my aux battery.. been years and years, but im not sure what the symptoms would be if it was bad...
i would hook a battery charger up to the main battery and see if things start to work, if they do than get a new battery, 6 years is getting pretty old anyways.
car key battery i would just replace for a few bucks and not worry if its the problem. 9 years old i would get one whether its your problem or not.
Old Jan 23, 2014 | 10:39 PM
AMG55TECH's Avatar
2004 E55, 2003 IS300
Bad key batteries will not stop the car from starting. The batteries are for just central locking and panic buttons... Don't believe me? Sit in your car, take the batteries out of the key and start the car. A lot of people don't know this. Charge or change your system battery in the trunk. If you get nothing, try another key. If you don't have another key to try, start by ordering a new key.
Old Jan 23, 2014 | 10:43 PM
03'55AMG's Avatar
AMG
^^^This.
The key is powered via induction while in the ignition, so with dead/low/no batteries the car will start and run normally. I would try another key and see if the problem persists.
Old Jan 23, 2014 | 10:44 PM
AMG55TECH's Avatar
Old Jan 24, 2014 | 12:46 AM
E55AMG05's Avatar
2005 E55 AMG
See that's how I know ^ that this guy knows what he's talking about. My rear battery has been dead before. I bought a battery charger from Walmart and charged it. Took 17hrs started at 7V completed at 14.5V went down to 13V. Ik this battery is bad plus it's 0 degrees here. Once in a whILE ESPECIALLY AT NIGHT I GET THE MESSAGE FUNCTIONS TEMPORARILY UNAVAILABLE < but ONLY ONCE IN A WHILE.
Old Jan 24, 2014 | 09:43 AM
thumper823's Avatar
04 E55
i Believe You
Old Jan 24, 2014 | 10:03 AM
sloanbj's Avatar
'72 Fleedwoot
You probably left it in gear
