Light weight rotors for 55 AMG Brakes?
Old Apr 10, 2014 | 10:44 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Hey Guys,
I have a CL600 with the upgraded 55 AMG brakes. I'm looking to get my car on a diet since its very very heavy and I think eliminating rotating mass as much as possible is where I should start. I did some research and found a few companies offering light weight rotors, but want to find out from guys on the forum of which ones really work the best. Did anyone get any 1/4 mile times with using lighter rotors and how much weight can really be saved?
Kamil
Old Apr 10, 2014 | 11:10 AM
Worth the wait's Avatar
2006 E55
https://mbworld.org/forums/showthread.php?t=451866
Old Apr 10, 2014 | 11:14 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Recent discussion:
https://mbworld.org/forums/w211-amg/...od-source.html
Two year old group-buy is still open?
Old Apr 10, 2014 | 11:52 AM
Toadster's Avatar
2005 E55 AMG
those weight reduced fronts will set you back ~ $1200
Old Apr 10, 2014 | 12:53 PM
I know it will be around $1000 give or take, what are the lightest ones at that price out there. I want to shave off as much weight as I can. I think the fastest 600 on here went 10.57 on Spray is was an S600. Im trying to get the record for stock turbos in the 1/4 mile so if I have to pay to shave weight to do it than I guess that's the only way. I will not be running spray but when I do the turbos in June I will be going after that Nitrous record car.
Old Apr 10, 2014 | 12:59 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
get rid of the mufflers on the car.
Old Apr 10, 2014 | 01:26 PM
Long Gone
Old Apr 10, 2014 | 01:34 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
I don't know who's making rotors now but I had the Evosport rotors and I don't recall seeing the noticeable difference in et's I was hoping for. I do remember them being supplied with EBC Red pads that caused a bunch of warranty issues with them.
Old Apr 10, 2014 | 02:34 PM
Do you remember te weight dif between the OEM and the rotors u got?
Old Apr 10, 2014 | 03:43 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I have evosport rotors but had to machine custom hats for my CL55 to make it all work. I weighed them all two years ago and think they were about 38 lbs lighter for both front and 20 on the rear. 58 lbs savings or so? Running a corvette C6 battery saved another 35 lbs or so.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 10, 2014 | 04:44 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Wi was going to go with these if I ever get 55/65 calipers for my S600.
http://www.girodisc.com/
Old Apr 10, 2014 | 04:51 PM
Girard@ACGautomotive's Avatar
a car
Girodisc made Evosport rotors long ago.
I always offer them as a nice solution to save some weight and add some performance.
Slotted only run $1050 and drilled slotted run $1125 per pair, front or rear.
I just did these on my P31 C63 (Same front rotor as E55) and saved a good amount. Plus they are correctly vented and look great
Let me know if you need a set.
OEM 2012 P31 C63 Rotor weighing in at 30.6 pounds:
Girodisc front 2 piece weighing in at 24 pounds:
Old Apr 17, 2014 | 12:46 AM
Will i need any modifications to get them to fit on my CL, again I have a CL600 with the CL55 AMG brakes.
Kamil
Old Apr 17, 2014 | 03:47 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I have Racing Brake rotors and pads on my SL55 nice quality set up
Old Apr 17, 2014 | 01:31 PM
vioilio's Avatar
2003 E55 AMG
I'm very happy with my Evosport rotors. I'm glad that when its time for a replacement I know where to go!
Old Apr 17, 2014 | 01:42 PM
Duc1098E500's Avatar
Honda Metropolitan
Evosport is no longer in business. They have also stolen my money for my unrecieved rotors.
Old Apr 17, 2014 | 01:59 PM
RacingBrake's Avatar
CLS550
CL600 / 55 AMG brakes
What year are the AMG brakes?
Old Apr 17, 2014 | 03:56 PM
PLATINUM SPONSOR
2003 CL55
What most are looking for , are the 2003-2006 E55 sets.
__________________
www.ultimatepd.com
Old Apr 17, 2014 | 04:29 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Originally Posted by kamilclk430
Hey Guys,
Kamil
See if BenzWorks can get you a set.
Old Apr 17, 2014 | 05:14 PM
vioilio's Avatar
2003 E55 AMG
I'm well aware that Evosport is no longer in business. I'm sorry for the troubles you had with them. My point was that I'm happy to know that when the time comes I know that I can order a new set from Girodisc.
Old Apr 17, 2014 | 06:51 PM
CLS550
Kamil
Kamil,
C63 and CL55 AMG (03-06) have the same rotor sizes for both front (360x36mm) and rear (330x26mm) but are different in height.
Using C63 rotors with your CL55 AMG brakes will not be a direct bolt on solution.
You should consider the following front and rear rotors that we make for CL55 AMG (03-06) models:
Front: https://www.racingbrake.com/ProductD...oductCode=2268
Rear: https://www.racingbrake.com/ProductD...oductCode=2269
Weight comparison (OE CL55 AMG vs RB):
Front OE one piece = 36.5 lbs
Front RB two-piece = 24 lbs
Total weight savings of 12.5 lbs
Rear OE one piece = 21.5 lbs
Rear RB two-piece = 15.2 lbs
Total weight savings of 6.3 lbs
Installing front and rear rotors from RacingBrake provides total weight savings of 37.6 lbs while maintaining the use of the stock emergency brake as well as improved braking performance and durability.
Old Apr 17, 2014 | 09:03 PM
Thericker's Avatar
V12-Biturbo
This... I bought mine from Surge
Old Apr 18, 2014 | 03:00 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I have a set of Carbon Ceramic rotors that I made for an W211E55. This will be your lightest option.
