Airmatic strut replace.. crazy easy
Old 04-30-2014, 04:46 PM
fergsc32's Avatar
2011 c63 AMG
so I go t my strut in.. I have to say. Ive done nuts to bolts DIY stuff for 15 years. This has to be..... by far..aside from a brake job... the easiest project ever on any car period. A handful of nuts on a wheel welL,,, and 4 totel on the strut plus 3 plug and play connections... all told start to finish in the driving rain BTW.. not even an hour. stupid easy.
car is a Dream now !
Old 04-30-2014, 04:48 PM
AMG E Power's Avatar
E55 amg
awesome !
Old 04-30-2014, 05:38 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Hardest part for me was getting enough air pressure out of it
Old 04-30-2014, 07:02 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Rear struts are even easier!
Old 04-30-2014, 07:51 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
lol
Old 04-30-2014, 09:22 PM
black06c230's Avatar
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
less than an hour for the front?? I've always heard thats more involved. Now the rears are stupid easy.
Old 04-30-2014, 09:25 PM
Duc1098E500's Avatar
Honda Metropolitan
Yeah changing shock and struts are easy. I did however swap to coilovers and I'm very much happy with it.
Old 04-30-2014, 11:43 PM
GregMB's Avatar
HA! What did I predict? It took you longer to replace your faulty keyboard, that it did to fix the strut.
-G
Old 05-01-2014, 08:27 AM
novae500's Avatar
W211
good to know when its time for me to change mine.
Old 05-01-2014, 10:55 AM
fergsc32's Avatar
2011 c63 AMG
I did not need to do this. I attached the strut to the top first witht he 3 nuts s... I then used a jack to slightly compress the strut while i applied downward pressure on the rotor with my chest.. WALA ! i then loosened the top mounts again while using ther jack under the rotor to align the bottom bolt.
Old 05-01-2014, 10:57 AM
fergsc32's Avatar
2011 c63 AMG
this was just one side.. the passenger side.. the most time consuming part is removing and installing the wheel well liner.. the strut itself literally comes out and goes back in in 20 minutes or less. if it wasnt a monsoon of rain.. it would have been even faster
Old 05-01-2014, 10:58 AM
fergsc32's Avatar
2011 c63 AMG
-G
PRETTY MUCH YOU WERE ON POINT..... oops damn keyboard
Old 03-22-2015, 11:11 AM
Sphinx144's Avatar
2006 E55 AMG, Alfa Romeo Stelvio Ti Sport
Is there any calibration that needs to be done when replacing the airmatic struts? My front ones are sagging and plan to replace them with new Arnott units this month.
Old 03-22-2015, 06:55 PM
HeissRod's Avatar
No, the car should self-calibrate.
Old 03-31-2015, 01:06 PM
Sphinx144's Avatar
what tool did you use to separate the control arm?
Old 03-31-2015, 01:59 PM
2000UZJ's Avatar
E55
I did the front in 45 minutes without really looking at any DIY's
Old 03-31-2015, 02:37 PM
Sphinx144's Avatar
How did you separate the joint ball from the control arm? Once you remove the bolt it doesn't slide right out.
Old 03-31-2015, 03:49 PM
2000UZJ's Avatar
E55
Remove the 3 bolts on the UCA. Don't pop the upper ball joint. I slide the strut out and installed the new one. I hooked up the air line and started the car once all buttoned up. It took about 2 minutes before the car realized it could raise it self back up. I did not use Star/DIS for anything.
https://mbworld.org/forums/w211-amg/...ml#post6151205
Old 03-31-2015, 06:04 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
To collapse mine, I lifted the affected corner with a floor jack and then opened and closed the drivers door with the key in my pocket. Did this a few times and each time the car would bleed that strut to try and level out the car. After about three rounds, the strut came right out. Mine was leaking, not completely failed.
Quick Reply: Airmatic strut replace.. crazy easy
