no looped rail and stock injectors
Old May 4, 2014 | 08:13 AM
macko's Avatar
e55 2005
Is it the ticking bomb? Is looped rail requires correction the ECU?
Does anyone monitor the EGT in #8?
Old May 4, 2014 | 09:51 AM
Hulk's Avatar
A Merc
It depends on how much boost you are running, usually your tuner will tell you if you are maxed out. Anything above 180 pulley requires bigger injectors.
The looped rail is to equalize the pressure in the rail
Old May 4, 2014 | 10:26 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
ummm depends on mods..
I got header 180cp and exhaust stock injectors no problems.
Old May 4, 2014 | 11:39 AM
macko's Avatar
e55 2005
engine mod: 180pulley 82TB kleemann headers no-primary cat. AFR is 11,5 about.
What do you think about it?
Old May 4, 2014 | 11:47 AM
Hulk's Avatar
A Merc
Getting a rail and bigger injectors and a custom tune will prolly get you maybe another 10hp, but in reality the added fuel is for safety. Afr at 11.5 is fine
Old May 4, 2014 | 11:55 AM
macko's Avatar
e55 2005
I have a bad experience with replacement injectors.
it makes sense to mount looped rail and stock injectors? in this case the ECU will be necessary to retune?
Old May 4, 2014 | 11:57 AM
Hulk's Avatar
A Merc
I have seen a few guys do that, and a retune was not needed, I think as long as you don't do any other mods you would be fine. What was wrong with replacement injectors?
Old May 4, 2014 | 12:16 PM
macko's Avatar
e55 2005
I have second fuel rail with blue injectors p/n 0280156304
actually I use p/n A1120780349:
Car runs great
I have bosch ev14 too, long story, very bad experience...
Old May 4, 2014 | 12:27 PM
Hulk's Avatar
A Merc
If you use the EV, you will need the pigtails to connect them securely
Old May 4, 2014 | 12:31 PM
macko's Avatar
e55 2005
Yes, I know.
Old May 4, 2014 | 12:35 PM
Hulk's Avatar
A Merc
With an 11.5 afr you are fine
Old May 4, 2014 | 12:54 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Car runs great
What happened with the ev14's?
Also, how much do those other MB injectors flow? A chart of applicable MB factory injectors with flow rates would be a good piece of info, unless one already exists.
Old May 4, 2014 | 12:59 PM
Hulk's Avatar
A Merc
There's a thread on it already, I think it was something like 480cc or something like that
Old May 4, 2014 | 01:53 PM
cm60k's Avatar
According to Stan Weiss,
SRT6/8 Blue injectors #: "0280 156 304", flows 543cc= 51.7lbs,
3.2K/55K Black injectors #: "0280 156 072", flows 397cc= 38lbs,
http://users.erols.com/srweiss/tableifc.htm
ZAYED,,
Old May 4, 2014 | 02:02 PM
macko's Avatar
e55 2005
ZAYED,,
Invaluable information. Thank you.
Old May 4, 2014 | 02:18 PM
macko's Avatar
e55 2005
from crossfireforum:
To summarize:
Stock SRT6 OEM, C/SLK 32 AMG, and early 5.5L SC AMG, black: Bosch 0280156072, MB 1120780349, 38-39 lb/hr depending on who's number you believe (@ 3 bar).
SRT6 replacement, late 5.5L SC AMG, light-blue: Bosch 0280156304. MB 1130780123, 44-45 lb/hr @ 3 bar, 4-hole.
Mclaren SLR, light-blue: Bosch 0280156148, MB 1550780049. 44-45 lb/hr @ 3 bar, 6-hole (better atomization).
Scott
Old May 4, 2014 | 02:33 PM
Hulk's Avatar
A Merc
Old May 4, 2014 | 03:35 PM
320 dreamer's Avatar
2003 porsche 996 turbo
ZAYED,,
that doesn't make any sense. the srt6 uses the same 3.2 s/c engine that the slk32 uses.
i would think it should be srt6/3.2 and srt8/55k engine
Old May 4, 2014 | 04:04 PM
macko's Avatar
e55 2005
http://www.crossfireforum.org/forum/crossfire-srt6/51220-stock-srt6-injector-flow-numbers.html
looks like that MB change injectors at 2006 year. My blue injectors are from 2010 g-class (g55 amg).
Old May 4, 2014 | 04:18 PM
cm60k's Avatar
Yes your right, MB replace their Injectors since 9/2005 from "112 078 03 49", which is "0280 156 072"
to "113 078 01 23", which is "0280 156 304"....
ZAYED,,
Old May 4, 2014 | 07:02 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
I don't know anything about the SRT-6's but these are the numbers I have for our injectors...
To summarize:
Scott
Old May 4, 2014 | 07:38 PM
AMGPower55's Avatar
2006 E55 AMG
So does that mean that the '06 model year 55's have the higher flowing injectors than the earlier model years? So '06 wouldn't need updated injectors to run 180mm crank pulley etc?
Old May 4, 2014 | 08:11 PM
Hulk's Avatar
A Merc
Yes the 06 have bigger injectors, although they are not 550cc . But if you have a 180 pulley you are fine, it's when you start ramping up more boost is where you have to be careful
chiromikey's Avatar
All models would be ok with a 180mm pulley but yes, the '06's had the blue injectors that were rated +6lbs over previous years'.
Old May 4, 2014 | 08:20 PM
AMGPower55's Avatar
2006 E55 AMG
Perfect thanks for the info!
