Looking for a M113k crank removal tool
*** Crank pulley tool ***
Anyone have one that fits the 55k harmonic balancer, i'm looking to purchase one. PM me
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
http://www.ebay.com/itm/Mercedes-Harmonic-Balancer-Holder-Tool-Crank-Pulley-E320-ML320-E430-ML430-C280-/371040795103?hash=item5663c139df&item=371040795103&pt=Motors_Automotive_Tools&vxp=mtr
They are definitely different ,I bought one from Benz ,I had to return the one they sell on ebay,even though I e mailed the guy and he assured me it would fit lol ,it's too big wont fit in lower pulley
thats probably what im going to have to end up doing. my other option is to buy the flywheel lock, or use a pry bar on the flywheel. im just not to fond on going that route.
PLATINUM SPONSOR
http://shop.ktcautotools.com/product...m156-m272-m273
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Takes a little more work but the flywheel lock tool for for the m113 is a good tool to use as wheel.
If you just want to loosen up the crank bolt you can brace a breaker bar against the floor or a block of wood and just touch the ignition key for a split second and it will pop loose.... I have done it a dozen times on American cars -- as long as the engine spins the same way it will work -- if you need a puller to pull the balancer off then then that is a different thing
that cannot be done on these, as these cars have a automatic start (meaning you don't hold the key to the starting position, and release once the car starts.) these you just turn to the starting position and release it, then the car will start it for you. think its related to the keyless go?
plus im changing pulleys, so i have a new crank bolt that has to be torqued to 150 foot lbs + 90 degrees, so i will need the tool, and a large torque wrench.
i had planned on doing the upper and lower pulley swap next weekend, when my SL will be on its "downtime". i have a list of things to do to it. im also in the process of ordering a torque wrench for the new crank bolt (so that might be a few days before i see that as well). so id hope to have the pulley swapped, by or around the week of the 19th.
2003 porsche 996 turbo
i think they are different, as i have looked at one on ebay. the one on ebay says 112k/113k "non compressor" engines... here is the link to the one that WILL NOT work...
Mercedes Harmonic Balancer Holder Tool Crank Pulley E320 ML320 E430 ML430 C280 | eBay
i would also suggest if your doing a crank pulley to use the pin kit from b/i. to many m113k cars have lost the crank pulley messing up the crank snout. ask gaspam from brentwood
