Sealant On Drain Plug Bolt
Old Jun 3, 2014 | 03:55 PM
Rallyboy383's Avatar
2004 E55
Okay, I am getting ready to change my oil on my 04 E55. Can I use oil drain plug sealant on the oil drain plug without problems? Permatex makes a sealant that is oil drain plug specific.
Old Jun 3, 2014 | 03:56 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
yes you should be fine.
MB recommends to change the drain plug and copper gasket. The OEM plug comes witt some sealant on it
Old Jun 3, 2014 | 05:04 PM
2004 E55
Is this a common practice? Will the sealant get in the oil?
Old Jun 3, 2014 | 05:26 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
alot of shops reuse the plug, clean it with wire wheel or brush replace the copper washer (napa sells a set or singles) apply small amount of sealant reinstall
Old Jun 3, 2014 | 05:34 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Or flip the washer around the other side and it'll crush differently and seal again
Old Jun 3, 2014 | 10:38 PM
Shifter's Avatar
E55, SL63, ML550
For god sakes at least replace the washer or your a hack.
Shifter's Avatar
E55, SL63, ML550
For god sakes at least replace the washer or your a hack. Flipping it does no good as both sides crush.
Old Jun 3, 2014 | 10:39 PM
Shifter's Avatar
E55, SL63, ML550
Something's up with replying sorry
Old Jun 3, 2014 | 11:12 PM
2004 E55
Thanks for all of the replies. I got it done and I did replace the copper washers.
Old Jun 4, 2014 | 09:39 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
That works too
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
