need help diagnosing S/C noise that's not the bearing
Any help would be very much appreciated.
Patrick
Here is the thread
https://mbworld.org/forums/w211-amg/...lse-video.html
Try removing shims from behind the pulley and get the clearence right.
EDIT:
should also mention that it seems the pulley plate that you are moving at the end is moving way too much.. mine is basicly solid. I think it might be a problem that needs to be fixed (new pulley?)
Here is what it looks like now after the bearing replacement. Still a ton of noise when just moving by hand. The bearing is new and made no noise so I know its not that. The gap now seems way better but I'll get a feeler on it to check, could be a bit close.
It seems like the noise is either the loose clutch plate itself or the black cylinder that the clutch pushes against (no idea the name of that is) between the pulley and s/c. Both seem to make noise when I spin them by hand.. Is that normal at all? Motor has 74k on it.
Any ideas on how to narrow it down?
How many shims do I need and any idea where to get them because I did a quick search and found nothing.
lol Shardul sells S/C pulley - get one from him and shims come free lol
