Zero boost (sometimes), no error codes, HELP please!
-hose behind the SC is loose
-a couple of hoses were loose
-one of the pulleys below the SC is in bad shape
A couple of things they noticed, my car is completely de-cat, and my mechanic plugged all 4 O2 sensors where the primary cats would be, dealer tech says they need more space between them, does that make sense?
Last, but not least, looped fuel rail and injectors, dealer tech says the injectors don't seem to fit properly, like "they don't go all the way in", and they show residue, like "leftover fuel after injection"...
Any and all feedback would be greatly appreciated.
As for the O2 sensors, you may need "cheaters" for the rear sensors. They are like little pipes that plug in where the rear ones go and then the sensors screw into those pipes. Having all those sensors so close probably had something to do with the fuel consumption.
You have a tune right? then the rear O2s have been turned off (or you would have had a cel all this time), as far as the car's Ecu is concerned, you do not have that option. Mine is turned off and I am getting 16 to 22 mpg on average depending on how much city driving I do.
My dealer will take pics and send them to me, I will post them here to get feedback
But there a lot of fuel residue, I don't see how these injectors can go all the way down.
But on the 82 mm TB there is no way connect it, and it's just there, sitting, I don't that should be the case.
Also, please have a look at the work this TB base has, two screws are loose were to 82mm TB is tightened.
As for that hose, you can put an oil catch can on it, maybe?
Does that make sense?
Where the rail bolts down, there are these "tabs" that stick out. Maybe if those tabs were raised up a bit, it would push the injectors farther down when it is bolted down?
Turns out my injectors were incorrectly installed, nobody at the dealer could tell what the difference was, it took SHARDUL a few looks at my pictures and he emailed me this "I know what the problem is with the injectors
The mechanic is using the wrong groove on the top to fasten the injectors to the fuel rail"
So, I told the dealer, and thats what it was... THANKS A LOT SHARDUL!!
My RPM sensor had gone bad, so the whole car was going on protection mode, dealer replaced the whole thing and the car is back to normal.
It was a crappy sensor causing all that agony
