Ride Height Button?
Old Jul 13, 2014 | 06:58 PM
Denis_E55's Avatar
09 S63
Ride Height Button?
Do you daily driving guys drive around with the ride height button on or off? I get on the highway and over 75mph? the car lowers it's self, I have 20" wheels and when I go to turn the fender is sitting ontop of the tire. I have adjustable links, should I adjust in the raised position or lowered?
Old Jul 13, 2014 | 08:19 PM
MomentumE55's Avatar
2004 E55
I would set in the lowered position surely you are talking about the fronts rubbing. Make sure they clear on lowest setting then you can raise it for whatever reason. You may have the wrong offset on your wheels. Do they stick out past the fender when aimed straight ahead and you look straight down from fender standing over wheel opening in body? Or possibly tire profile is too wide. I have Hankook Ventus 20" and they are clearing fine. I have links too but lowest setting is not slammed. Still 1/2" or so clearance from top of tire to fender.
Old Jul 13, 2014 | 09:50 PM
Denis_E55's Avatar
09 S63
So with your ride height button off, you have about 1/2" clearence? Do you drive it daily with the car in the low setting?
Old Jul 14, 2014 | 01:09 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
in sport 2 mode(2 lights on) is where you should adjust your lowering links. "off" is comfort mode, Sport 2 is what your car lowers itself to at 72 mph on the highway whether the light is on or not.
I myself drive around in sport 2 unless I commute to work, in which case I am in comfort mode, and even raise it a bit
Old Jul 14, 2014 | 01:12 PM
Denis_E55's Avatar
09 S63
So 2 LIGHTS ON, What about the RIDE HEIGHT button? It should be OFF (low setting) right?
Old Jul 14, 2014 | 01:42 PM
GregMB's Avatar
You're talking about RAISED MODE.
That's typically for driving in deep snow (or for use at the dragstrip for better rear weight transfer)..... Leave that off. It disables itself at highway speeds anyway.
-G
Old Jul 14, 2014 | 01:52 PM
jcjmw's Avatar
2005 E55 Wagon
-G
Or carrying a lot of groceries in your E55 Wagon!
Old Jul 14, 2014 | 02:08 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Old Jul 14, 2014 | 04:01 PM
berti_00's Avatar
2016 Cls63s AMG
Hey so if you adjust your links on sport 1 light and when you go into two lights it goes lower???
Old Jul 20, 2014 | 10:18 AM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
-G
I always thought RAISED MODE was for driving over rough terrain or raising the vehicle in case the lip or bumper gets caught on a gutter. Or maybe it's just promoted accordingly for different regions where sold? At any rate the vehicle does drive MUCH better at the correct ride hight with superior handling and comfort.
In addition to the deteriorated ride, from what I can tell driving in raised mode puts extra strain on the shocks (probably the entire Airmatic system). I stayed in a chalet earlier this year and had to travel a rough dirt road to get there including a large mound where the car bottomed out - at least until I switched to raised mode. I didn't remember it was still on when driving away until after about 10 miles when I immediately lowered and felt the car siink into a balanced and more comfortable stance. A few days later one of the front shock's developed a high piercing leak and had to be replaced with the other front shock also leaking within 3 weeks.
It pays to maintain the Airmatic system and change fluid regularly - there are other threads here that stress the importance as repairs can become frequent and costly otherwise. The consensus is Airmatic will run without issues for over 300,000 miles if correctly maintained.
Old Aug 7, 2014 | 05:24 PM
hopodia's Avatar
2007 E 63 AMG Black on black, 2004 Screaming Yellow Mach 1 Mustang & a '96 Tacoma pickup partschaser
Aloha THETHERAPIST, do you know where can I find a maintenance schedule/program for the Airmatic system?
Old Aug 7, 2014 | 06:46 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
What fluid and maintenance are you referring to? I thought that was for ABC equipped
cars
Old Aug 8, 2014 | 10:43 PM
JDM_SXE-10's Avatar
2003 E500
I was wondering the same thing because I have never noticed any difference in height, only stiffness.
Old Aug 9, 2014 | 06:33 AM
GregMB's Avatar
Sport 1 & Sport 2 are the exact same height.
-G
Old Aug 9, 2014 | 09:06 AM
cij911's Avatar
one car at a time
-G
Greg - I don't believe that to be true....I believe the Sport II height is slightly lower (~10mm) - see HiessRod's post above....
Old Aug 9, 2014 | 09:33 AM
GregMB's Avatar
You're right. My bad.... I was thinking about the lowering effect at ~70mph. Neither sport1 or sport2 get any lower than their normal ride heights. Only "comfort" changes at speed.
To improve tire wear, I am now running in Sport1 mode and have my alignment set up for that height. I used to run in Comfort Mode, but the alignment settings change enough with dynamic lowering (highway speeds) that you can't really trust that the alignment is still perfect.....especially toe.
-G
Old Aug 9, 2014 | 01:34 PM
James M's Avatar
03 E55 AMG
I always have my car on the Sport II setting and it wears out the inside of my tyres something terrible. Only realized I should have had it set to this when I had my last alignment done. I was also amazed at how much more traction I got with the car in comfort mode (sport I and II switched off).
Old Aug 9, 2014 | 08:36 PM
JDM_SXE-10's Avatar
2003 E500
I'm in Sport I almost all the time too, and have never noticed a height difference when I toggled between the different settings. I played with it before and it always appeared to be right at the same spot on my tire no matter which mode I was in. I guess I have to pay closer attention next time.
Old Aug 9, 2014 | 10:38 PM
cij911's Avatar
one car at a time
Just read the owners manual ....
