Trying to install rear K-mac, something went wrong
Old Jul 19, 2014 | 02:39 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
My air spring is pushing everything outward. The Jack stand under the A-arm tipped with it. How do I get the pressure out of this thing! I've got a floor jack under the A-arm but can't jack it in the direction I need it to go. I may have already ruined my air spring extending it at this screwy angle. Any help please.
Russ
Attached Thumbnails Trying to install rear K-mac, something went wrong-dscn5303.jpg
Old Jul 19, 2014 | 04:36 PM
Denroll's Avatar
'06 E55
If you don't have Star, you will have to "trick" it with the sensor. I'm sure there are detailed instructions somewhere on here.
Old Jul 19, 2014 | 08:28 PM
I got it done. Seems to be okay. Couldn't get the rear sensor to drop, the front is easy to trick . I ended up just pulling it back against the corner of the garage and bracing the car to keep from pulling it off the stands. I'd make a DIY but I'm pretty sure this how NOT to do it. I did the second one with the wheel holding it steady and a hand winch to pull it into place
I'm actually quite impressed with the engineering of this system, if this won't hold I don't know what would. I only made one small change. I don't know if it will make much difference but I wanted a little more bite into the aluminum arm so I put in a toothed piece of Chevy push rod.(best steel I had on hand)
Attached Thumbnails Trying to install rear K-mac, something went wrong-dscn5294.jpg   Trying to install rear K-mac, something went wrong-dscn5308.jpg   Trying to install rear K-mac, something went wrong-dscn5311.jpg   Trying to install rear K-mac, something went wrong-dscn5304.jpg
Old Jul 19, 2014 | 08:54 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Time for some new tires soon too! Let us know if the inside wear truly is less with the KMAC set up!
Old Jul 20, 2014 | 06:47 AM
MindBend's Avatar
'05 E55
Starving, I salute you--you're into every system in that car, from your recent posts...and some creativity too (hence "starvingartist, I suppose) Git'er whipped into shape and start some white smoke burn-out action!
Old Jul 20, 2014 | 06:53 AM
Thanks man, Wait till you see what I did to the oil pump chain.
Old Jul 20, 2014 | 06:56 AM
MindBend's Avatar
'05 E55
Do tell! Mine is slapping around and may eventually cause me to launch yet another quest for pain...
Be sure to pay attention to SirBoostALot here. He's a brilliant scientist with these motors and has built a mega-motor for his own CLS....and E55...and ....
Old Jul 20, 2014 | 07:46 AM
Oh I do! I read every day and even take notes.
I'll get some pictures up later when my wife gets up. I don't have much patience for this computer stuff.
Old Jul 20, 2014 | 07:48 AM
MindBend's Avatar
'05 E55
OK cool.
If you're an artist w/o patience for this computer stuff, may explain the "starving" part!
Old Jul 20, 2014 | 07:51 AM
