Anyone on here stack a 185mm CP and clutched 84mm S/C??
I used to just run a eurocharged s/c pulley and recently switched to the 185mm crank pulley and honestly I love it the gains I got were a incredible difference and me and my mechanic were talking how we could squeeze more power out of her so he asked me why not run the 84mm s/c pulley on top of the crank pulley hmm yea seemed like a good idea an easy power so we tried researching if anyone ran the setup and honestly found absolutely nothing! So what am asking is anyone running this setup what are the ups/downs etc? Here is my mod list
185mm crank pulley
Ported supercharger
BBK 90mm T/B
Devils own methanol stage 1
BIP Looped fuel rail
AEM 320lph fuel pumps
PTE 170f Tstat
Needswings cold air intake
Eurocharged belt wrap kit
Kleeman headers 3 inch X-pipe no cats or resonator custom 3 inch Catback with eurocharged mufflers
Eurocharged ECU/TCU
Split cooling FTP engine bay tank
550cc injectors
Eurocharged H/E
Johnson c30 pump
Ngk Colder step plugs
Any suggestion or input is much appreciated!!!
I would add a killer chiller to your combo or you could cool the charge with a small 50 wet shot.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
and I do plan on going with the long tubes I got a deal on the Kleemans I just couldn't pass up.
