Very dim A/C display. Anyone experienced issues before?
Old Aug 8, 2014 | 02:31 AM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Arrow Very dim A/C display. Anyone experienced issues before?
Hi guys,
Quick question…
I just picked up my car from the dealer this morning. It’s been with them for two weeks. I had several things repaired/replaced under warranty.
Just as a side note for bragging purposes, I was fortunate enough that my entire panoramic roof assembly was replaced. You know how most pano roofs have issues closing? That “machine gun” noise that it creates because of the motor. Well… my Daimler Chrysler extended warranty approved the requested repair and ended up changing the whole thing. The cost of that alone was $7,481. My out of pocket cost was $200 for the deductible.
Anyways… back to the issue at hand. I had other things replaced as well… certain cooling hoses and other items relating to the A/C and heater. As I was on my way home, I turned on the A/C (which works fine), but I noticed that the A/C display is so dim that you can’t even tell that it’s on. I haven’t called my advisor yet, cause I want to see if anyone has experienced such an issue. The display isn’t “white” like it should be. It’s so dim that it blends in with the background.
If anyone happens to know what may be causing this or possibly have experienced this in the past, please let me know if there is a quick solution to this.
Any help is very much appreciated.
Thank you in advance.
Old Aug 8, 2014 | 03:09 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Time for a new climate control unit as well
Old Aug 8, 2014 | 03:13 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
It was probably around twilight when it happened and it's simply your car auto headlights coming on and switching your dash to night settings. Turn off your head lights when it happens next time to check if the dash goes back to day time brightness. If that's it just adjust your night time display from the dash knob or turn off the night time settings through command.
Old Aug 8, 2014 | 01:59 PM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
I had the same issue after having the pano roof in my E500 replaced (CPO warranty). I brought it back to the dealer to have them fix it. SA said it was a damaged wire to the overhead control panel.
Old Aug 8, 2014 | 04:42 PM
chiromikey's Avatar
Guys, if the command screen is also dark it's in night time dim mode and all he has to do is turn the dash knob clockwise...
Old Aug 8, 2014 | 05:08 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
The tape wire that goes from the sunlight sensor to the area where the controls for the roof are has been damaged. Mine is doing the same thing. Let us know what your fix is.
Old Aug 10, 2014 | 11:21 PM
Unfortunately, that's not the case. That's the very first thing i tried doing. When turning the knob, all dash lights get brighter except for the A/C display.
I think you and i really are having the same problem. I'm going to bring it back to the dealer sometime this week and see what they can do. Not only is my A/C display practically gone, my radio doesn't brighten/dim during the day/night. The dealer technicians might have possibly screwed something up when re-installing the parts above the rear view mirror.
Old Aug 10, 2014 | 11:59 PM
JDM_SXE-10's Avatar
2003 E500
This happened to me a few years back and it has never happened again since. It was so dim that it was illegible and it was like that for a few days. It suddenly went away and has not happened since. I never did figure out what caused it.
Old Aug 11, 2014 | 03:09 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Mines dim also. Need to look into this ribbon cable I suspect.
Old Aug 12, 2014 | 01:27 AM
Interesting that you mentioned that, my display now "somewhat shows". It's not as "invisible" as it was these past few days. But it's still not as visible/bright as it should be.
I'm just waiting for my service advisor to return my call so that i can bring the car in for re-inspection of the poor work that was done.
A pet peeve of mine... is when a customer takes his/her car into the dealer and receives it back with additional problems the car never had.
Old Aug 15, 2014 | 01:29 PM
The dealer found the issue. When the technician re-installed some of the wiring directly above the rear view mirror, one of the thin connectors (i apologize, i don't recall what it's called) got jammed between something and was cut.
The dealer ordered a replacement part and will install it free of charge since the problem was caused on their end. Total time to completely replace is estimated to be between 20-30 mins.
Problem solved. Good thing I didn't need a new A/C climate control cluster.
As a side note for those who are experiencing the same problem, the best way i can describe the part is... it's a really thin, white, flat electrical band with black connectors on both ends. I wanna say its about a 10-12 inches or less.
Hope this helps.
Old Aug 15, 2014 | 01:38 PM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Glad to hear it's being taken care of.
Old Aug 18, 2014 | 08:18 PM
Bigtickets's Avatar
How much was the part?
Old Aug 18, 2014 | 11:51 PM
I'll ask pricing for you when I bring back the car to get it fixed. Just waiting for a call to notify me that the part is in.
Old Aug 21, 2014 | 01:31 PM
UPDATE
The dealer replaced the connector piece and the problem was solved.
No more dim A/C display.
The radio down auto dims and brightens accordingly.
Here is the part number below. Not sure how much it cost.
Old Aug 21, 2014 | 04:11 PM
JDM_SXE-10's Avatar
2003 E500
I just looked it up and MSRP is $13.50.
Old Aug 21, 2014 | 04:52 PM
Wow... that's a major loss on my end.
I spent more gas money driving to the dealership several times just for them to inspect the issue, then come back a 2nd time for installation. And this was after getting my car back from $11k+ of warranty work.
Cheap fix for everyone else.
Old Jun 28, 2018 | 12:58 AM
Dtloveridge's Avatar
W211 E55
Worked like a champ
This fix worked perfect for me. Was having issues with dim climate control. Found out that white flat wire had been cut (probably from windshield company). Replaced and now she lights up like a champ.
Thank you you all for posting this simple but awesome fix
Old Nov 9, 2020 | 09:54 PM
gogydm's Avatar
08 E350
I've got a similar issue. Climate control is always very dim but my headlights and interior lights work as they should. I also believe that my windshield wipers sensor works as intended. Would it be the same cable that is being discussed in this thread? What is the part number? Thank you for your help.
Old Dec 3, 2020 | 02:10 PM
streetspeeder's Avatar
2006 E55 AMG
Hi,
What was the part number that you looked up? I'll look up where it is and how to install.
I've had the same issue for years and didnt worry about it...
Old Apr 4, 2023 | 08:37 PM
Report rub1233's Avatar
'90 W124 250D Turbo OM602 | '09 W211 280 CDI
Yeah if someone could reupload the photo that'd be great. The old photo is down.
Old Apr 4, 2023 | 08:49 PM
austingtir's Avatar
There is actually a backround menu somewhere in that display where you can turn up the brightness a bit that sorted my issue. Cant remember how or what I did tho was ages ago.
Old Feb 12, 2026 | 12:53 PM
Beachmark9@gmai's Avatar
2016 E 400 Cabriolet
Originally Posted by babyboigsxr
Hi guys,
Quick question…
To recap, the solution was an ribbon wire cut, running up the glass above the rear view mirror assembly. Part cost under $14.00. Did anyone find the part number?
thanks so much, dim display on AC driving me crazy.
Old Feb 12, 2026 | 01:07 PM
This runs along the windshield upward?
Old Feb 12, 2026 | 01:11 PM
Part number?
