DashDaq XL Rediness Monitoring
Old Aug 22, 2014 | 10:54 AM
vioilio's Avatar
2003 E55 AMG
This may seem like a stupid question for some of you. How in the world I can monitor Readiness Status of the different components via my DashDaq XL??? For the life of my I can not find it anywhere in the menus or figure it out! Also what formula re you guys using for monitoring boost. The one in the user manual is useless and it is not correct.
Thanks a ton!
Old Aug 22, 2014 | 10:56 AM
Hulk's Avatar
A Merc
Boost via obd?
Old Aug 22, 2014 | 11:00 AM
vioilio's Avatar
2003 E55 AMG
Originally Posted by Hulk
Boost via obd?
correct
Old Aug 22, 2014 | 11:01 AM
Hulk's Avatar
A Merc
Input Signal: MAP
Multiplier Signal: Constant Multiplier from Rescale Calculator
Multiplier Sign: 1
Constant Multiplier: 1
Offset Signal: Constant Offset from Rescale calculator
Offset Sign: -1
Constant Offset: 14.7
Name it : boost
Grip grip made this and it works
btw try to get a zt2 and get the boost sensor so it's real time
Old Aug 22, 2014 | 11:02 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
subtract barometric atmosphere from MAP value
Old Aug 22, 2014 | 11:03 AM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
Here's the settings from the manufacturer that worked like a charm:
Try these settings in your calculator:
Input Signal: MAP
Multiplier Sign: 1
Offset Sign: -1
Grip Grip's Avatar
Thanks Hulk, you beat me to it.
Old Aug 22, 2014 | 11:05 AM
Hulk's Avatar
A Merc
Old Aug 22, 2014 | 11:09 AM
vioilio's Avatar
2003 E55 AMG
Thanks a looottt!!!! I will try the boost calculation method. Any help on the readiness readings/monitoring?
Old Aug 22, 2014 | 11:11 AM
Hulk's Avatar
A Merc
What do you mean by readiness? Is you dashdaq not picking up the obd signals? If that's the case go to settings and scan via obd for signals and you should have everything. Available through obd in your list
Old Aug 22, 2014 | 11:17 AM
vioilio's Avatar
2003 E55 AMG
What I mean is that you can see which system is ready and which not. Drive cycle status.
Old Aug 22, 2014 | 12:33 PM
Hulk's Avatar
A Merc
Never used it for that sorry
Old Aug 22, 2014 | 12:58 PM
Denroll's Avatar
'06 E55
Do you have the ZT-2? The boost sensor is not very expensive and tapping the surge tank is not very hard. Real-time boost readout without the lag sure is nice to have and doesn't look like stair steps on your data logs.
Old Aug 22, 2014 | 01:40 PM
vioilio's Avatar
2003 E55 AMG
Yes Sir, I do have the ZT-2. There was a guy here selling surge tanks with a tap in the passenger side for boost sensor. Can you tell me what exactly do i need as far a sensor goes?
Old Aug 22, 2014 | 02:02 PM
Hulk's Avatar
A Merc
http://www.ebay.com/itm/Zeitronix-MAP-Sensor-50psi-3-5-Bar-Boost-/291149125684?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c9d71834&vxp=mtr
Tap the side or end of the surge tank
Old Aug 22, 2014 | 02:06 PM
vioilio's Avatar
2003 E55 AMG
Zeitronix Map Sensor 50PSI 3 5 Bar Boost | eBay
Does it matter where exactly?
Old Aug 22, 2014 | 02:19 PM
Denroll's Avatar
'06 E55
Not really. Mine is right there by the oil dipstick tube:
Surge tank is really easy to remove. You'll want to remove it so the shavings don't go into the engine (duh).
Old Aug 22, 2014 | 02:32 PM
Hulk's Avatar
A Merc
You can put it there however I will be moving mine to the end to clean the look up and hide it
Old Aug 23, 2014 | 11:10 AM
vioilio's Avatar
2003 E55 AMG
Input Signal: MAP
Multiplier Sign: 1
Offset Sign: -1
Name it : boost
Input Signal: MAP
Multiplier Sign: 1
Offset Sign: -1
This is exactly what i'm using but it does not seems to work for me. Numbers are always negative and looks like -xxx.xxxx
Old Aug 23, 2014 | 11:35 AM
Hulk's Avatar
A Merc
Hmm weird I used that exactly before I got the zeitronix boost sensor and worked fine and on a few guys Los, can you double check that the negative sign is on where it should be
Old Aug 23, 2014 | 11:49 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Also get a good tap for it .. These are decent quality taps. I tried using a cheap harbor freight tap I had in a set .. almost ruined the hole.
This is one I bought and used:
Amazon Amazon
