Ok guys I need to change my sparkplugs and I was wondering what are the best plugs for our 55 ?i am in a eurocharged tune and s/c pulley so does that mean colder sparks ? Thanks guys appreciate it
I have the same setup, the plugs I use that also are recommended on here are the NGK LFR7AIX
Quote:
How are thy now? feeling the car better ? Where can I purchased themOriginally Posted by vikingdiesel
you can purchase them online, ebay have good prices too. while you are at it, take a good look at your plug wires and make sure no heat damage and everything is in good order. check the valve covers corners looking for that slow oil leak that our covers are known for and do that maintenance while your are at it and use sealant when replacing to avoid that in the future. replace air filters if not done for sometime and hope you will see/feel some difference!
Quote:
Awesome thanks man will do ..you know what I do think I need new sealant because my car asks me for 1qt every 2 monthsso I have a small leak somewhere . Also what wires do you recommend us ..Originally Posted by green1212
Quote:
Thats a good questionOriginally Posted by venomsE55
what plug wires do you recommend?
Magnecor wires
ExploreSenior Member
you know about the wires, oem would not be bad. no one has found any problems with them and they last a very long time. up to 100,000 miles and in some cases, people have run them longer too. but what i have done is use some dielectric grease inside the boot that goes over the actual spark plug tip on all my wires. keeps water out and make for a good "seal" and conductor. in the diy, that member used evosport plugs and they looked quite well too.
Crissus
close
- Join DateNov 2012
- LocationGermany
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveC215 CL55 AMG, W124 500E, W210 E430, W124 300E
Liked:16 Times in 13 Posts
NEVER use any sealant (RTVs, etc) at any Mercedes Valve Cover Gaskets for "dressing". Do that with the american cars, fine. But not on Mercedes - please.
Its a mess and can clog oil-lines back from the heads. Seen that too often to not care about such statements...
The valvecover gaskets are pennies on the dollar from Elring,etc in the aftermarket (OEMs).
