Add me to the list of failed SBC...
Old Oct 6, 2014 | 07:18 PM
  #51
Shifter's Avatar
E55, SL63, ML550
Mid to late production 06 means model year 07. Hence E63.
Old Oct 6, 2014 | 11:41 PM
  #52
JDM_SXE-10's Avatar
2003 E500
That's right, so I guess the people with 2006s do have SBC.
Old Oct 7, 2014 | 05:50 AM
  #53
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Originally Posted by JDM_SXE-10
It looks like the SBC unit is the same part number for my 2003 E500 and your 2005 E55:
0004300712
Thank you!!!! I was going nuts trying to narrow down the right part number even to reference what we're talking about. The part isn't listed as an SBC pump.
Old Oct 7, 2014 | 10:31 AM
  #54
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
from my understanding all e55's have SBC
Old Oct 7, 2014 | 11:53 AM
  #55
O-55's Avatar
2005 E55, 2009 VW GLI
Originally Posted by WANTED!!
SO, my original question still stands. Does anyone have the part number for a 2005 e55 SBC pump?
Here you go:
A 005 431 81 12
Old Oct 7, 2014 | 01:49 PM
  #56
JDM_SXE-10's Avatar
2003 E500
I just double checked and it appears that O-55 has the correct part number. Disregard mine and refer to post #55. It should be A0054318112.
Old Oct 7, 2014 | 08:23 PM
  #57
Benz-O-Rama's Avatar
Originally Posted by shardul
IMO the counter set in accordance with the lifespan of the components of the units. Yes you can reset the counter but then you would have a SBC unit with parts that have exceeded their useful life.
Bingo.
Sure, there's little tools out there that will reset the counter. But guys, that's not gonna keep it from failing. Would you really want to be driving this thing after rewriting the EEPROM, knowing everytime you take it out you could be risking serious injury to whomever is driving, and all the innocents around you? Those that have had this failure will tell you it's more than a bit unnerving when it happens. I was lucky that it was very early morning, small back roads, and no traffic. The 5 miles or so back home were not for the feint of heart.
All of these early production year 211s will have to deal with this. Start budgeting now...
Old Oct 7, 2014 | 08:51 PM
  #58
p30amg08's Avatar
Originally Posted by Benz-O-Rama
Bingo.
Sure, there's little tools out there that will reset the counter. But guys, that's not gonna keep it from failing. Would you really want to be driving this thing after rewriting the EEPROM, knowing everytime you take it out you could be risking serious injury to whomever is driving all the innocents around you? Those that have had this failure will tell you it's more than a bit unnerving when it happens. I was lucky that it was very early morning, small back roads, and no traffic. The 5 miles or so back home were not for the feint of heart.
How this has not been a lawsuit already is baffling
Old Oct 7, 2014 | 09:17 PM
  #59
Jack661199's Avatar
2003 E320 (W211) also starting to look for a CL55 or E55
Bingo.
It's a lot more than a bit unnerving when it fails it turns stoping your can into stopping a rocket
Old Jan 1, 2015 | 04:22 PM
  #60
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
I found this but can't find menu option in SDS C4? Maybe it is geared towards C3?
RESET SBC SERVICE LIGHT:
1st: make sure that engine is running!!! In SD Developer mode you need to go to:
Entwickelingsdaten (developer data) ---> ansteueringen (control gear) ---> Gesamstliste aller Ansteuerungen (complete list of all the control circuits).
To see how many times brake has been pressed there is a line that says:
Bremsenzahler (DJ_GetBrLive) (brake payer (dj_getbrlive)).
Then 1 line down there you see:
Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen (brake upgrade and lifetime payer payers recalculated f) -> click it ! Parameter uINBR = 0 then click F3
1 line down you see (or search for this line):
Bremsenzahler auf beliebigen Wert setzen (DJ_SetNBr) -> click it Parameter uINBR = 0 then click F3
then scroll down until you see the line's:
Lebensdauerzahler F neu berechenen (DJ_CalcLiveTime) Parameter uINBR = 0 then click F3
Lebensdauerzahler F neu berechenen und schreiben (DJ_BuildAndWriteF) Parameter uINBR = 0 then click F3
Log out of SBC !! Log out of vehicle!! Let engine run at least 10 minutes or drive at least 10 minutes if no coils are damaged, SBC fault code is not AKTUEL no more
Old Jan 8, 2015 | 06:02 AM
  #61
WANTED!!'s Avatar
So mine failed too, finally. And it just so happened to have happened with DAYS to spare left on the SBC warranty. Was contacted by the dealer yesterday and was told they're covering it.
Who has two thumbs and is one lucky SOB? THIS GUY!!!!
Old Jan 8, 2015 | 08:31 AM
  #62
uraberg's Avatar
2006 E55 AMG
Yikes. This -almost- makes me hope mine fails too within the next 5 months.
Did you have an immediate catastrophic failure, or did you get any warning?
Old Jan 8, 2015 | 09:33 AM
  #63
2000UZJ's Avatar
E55
Mine is going strong and my warranty ended last March. I am having the dealer pull the # of cycles and that should tell me when I should start saving.
Old Jan 8, 2015 | 10:39 AM
  #64
veryswag's Avatar
2004 E55 AMG, 2005 E55 AMG (Sold)
how many miles do you have on your car?
Old Jan 8, 2015 | 11:22 AM
  #65
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
Is it possible to retrofit the newer non sbc brake system in?
Old Jan 8, 2015 | 11:47 AM
  #66
veryswag's Avatar
Has anyone had the pump replaced at the stealership & know how many labor hrs the job was ?
Old Jan 8, 2015 | 12:51 PM
  #67
Rocman8's Avatar
E55
on the e55 it usually runs about 6 hrs including diagnosis. average labor rate around 150-175 an hr.
Old Jan 8, 2015 | 01:48 PM
  #68
WANTED!!'s Avatar
Not really. I was on the highway traveling at 75 when I got the flashing red dash message of death. Had it not been early on a Saturday morning, it could have been bad.
Old Jan 8, 2015 | 01:49 PM
  #69
WANTED!!'s Avatar
Under 80k.
Old Jan 8, 2015 | 01:55 PM
  #70
Rocman8's Avatar
E55
a little advice for everyone almost out of the 10 year warranty on sbc. the sbc service threshold life can be checked with sds even before a warning comes up and it can be programmed or replaced if needed.
before the warranty expires take it to the dealer and pay for an "a" or "b" service and make sure they check the service life as it is required on the service sheet to do so. then if they find that the pump needs replaced or programmed it can be done right then and there.
Old Jan 8, 2015 | 02:16 PM
  #71
2000UZJ's Avatar
E55
I would think so, but then again a lot of parts and probably coding the ECU.
Old Jan 8, 2015 | 03:12 PM
  #72
Mikeki7's Avatar
CLS63, S55
Does the sbc pump actually fail when the red message appears or it gets disabled because it has reached the max amount of actuations? If it doesn't actually fail why was it designed this way? If one was to reset the sbc it can continue working and may potentially never break? obviously not recommended but just interested. Now that these cars are starting to get out of coverage for the sbc, more people should start looking into rebuilding them.
Old Jan 8, 2015 | 03:42 PM
  #73
forcefed4door's Avatar
05 E55, 06 Audi S4
I assume it was designed this way so preventative maintenence would occur before an actual catastrophic failure on the highway. Kinda like our fuel pump assembly:-).
Old Jan 8, 2015 | 04:06 PM
  #74
veryswag's Avatar
Under 80k.
well thats comforting ...im at 79k
Old Jan 8, 2015 | 04:07 PM
  #75
2000UZJ's Avatar
E55
you??? I'm at 88K
