Secondary air pump elimination question for those who've done it
Subscribe
Oct 10, 2014 | 10:00 PM
SO a quick questions for those who've done this before. Do you cap off the nipple on nipple on the supercharger or does it need to continue to have air exposure. Here's a picture for reference. Thanks in advance.
Jon
Reply 0
Oct 11, 2014 | 07:05 AM
No one has done this yet? I swore I read of others guys doing this. Coding is not an issue as I have STAR.
Reply 0
Oct 11, 2014 | 08:36 AM
You can disable with with star and cap both the bottom ports
Reply 0
Oct 11, 2014 | 08:54 AM
I swear you're a hyper-vigilant insomniac that lives on the board.
BTW, did what I could of a comparison between my 84mm "chop saw" and the new pulley you sent me. There are a few differences including weight and fitment.
Reply 0
Oct 11, 2014 | 09:14 AM
Just turn it off via star
I did it and no more code
https://mbworld.org/forums/w211-amg/491094-diagnose-secondary-air-injection-egr-post-cat-02-sensors-through-sds.html
Reply 0
Oct 12, 2014 | 03:57 PM
I have tried with my specialist using his MB tool and it won't let us into the secondary air injection pump section to disable it. Had the damn 'check engine' light on for months. Another tuner wants to charge me $ 250.00 to do it - rip off for 5 minutes work with the correct tool.
Reply 0
Oct 12, 2014 | 04:55 PM
If the star doesn't have developer mode it won't be able to access it
Reply 1
Oct 12, 2014 | 09:09 PM
May l ask what's the reason for doing that?
Reply 0
Explore
Oct 12, 2014 | 09:34 PM
Because when that pump goes out it sends a check engine light, that pump is used for smog so instead of shelling out money for a new pump just code it out
Reply 0
Oct 12, 2014 | 09:39 PM
Ok got it .thanks
Reply 0
Oct 13, 2014 | 03:04 AM
I thought that the secondary air pump was only on the nauraly aspirated 55's
Where do we have this? Is it on cars or just US models?
Reply 0
Oct 13, 2014 | 04:58 AM
European cars have them too. In fact the W211 E55 has exactly the same one found on the N/A E500's. On the RHD European models they are situated under right hand headlight if you are facing the car. I know this because I was advised to find a used one off a wreck as they sell for $1000 new from the dealership. The problem is most wrecks are front end.
Reply 0
Oct 13, 2014 | 07:44 AM
Quote: European cars have them too. In fact the W211 E55 has exactly the same one found on the N/A E500's. On the RHD European models they are situated under right hand headlight I you are facing the car. I know this because I was advised to find a used one off a wreck as they sell for $1000 new from the dealership. The problem is most wrecks are front end.
OK good to know, here in Finland we drive on the rightside ofthe road. On the right side when facing the car I have the airmatic kompressor, is it next to it?
Reply 0
Oct 13, 2014 | 07:47 AM
Quote: May l ask what's the reason for doing that?
Only reason I'm eliminating mine is to free up a little space and reduce the possibility of one more thing failing.
Reply 0
Oct 13, 2014 | 07:50 AM
Quote: OK good to know, here in Finland we drive on the rightside ofthe road. On the right side when facing the car I have the airmatic kompressor, is it next to it?
You got it - right next to it! A glorified hairdryer worth $1000.00.
Reply 0
Oct 13, 2014 | 05:31 PM
Quote: You got it - right next to it! A glorified hairdryer worth $1000.00.
... but srsly
Reply 0
Oct 14, 2014 | 02:14 AM
what is the reason for blanking off those openings?
is this just to pass smog tests??
Reply 0
Oct 14, 2014 | 04:39 AM
Actually, I only blanked the lower one that the pump feeds into and left the other ones alone.
Well after the fact, but does anyone out there make block off plates for the rest of the system? It sure would have been handy when I did the looped fuel setup to not have it in the way, although it was doable with a little bit of quality time with the air grinder.
Reply 0
Oct 14, 2014 | 04:41 AM
Actually, depending on the rules of where you live, you won't pass smog if it's not present.
Reply 0
Oct 16, 2014 | 10:06 PM
I actually just got the CEL the other day and need to deactivate them but my xentry will not work right now. Would be night if there was some type of block off plate option.
Reply 0
Subscribe
Currently Active Users (1)
