E55 Steering Wheel Locked
Old Oct 19, 2014 | 08:03 PM
Vanquish59's Avatar
2019 S63 AMG (Current), 2015 E63S, 2008 E63, 2005 E55
Today when I was driving, I made a right turn (semi-sharp) into a parking lot. I stopped and I couldn't turn the wheel left or right anymore. It was completely locked and a red car symbol showed up on my dashboard. Anyone know the cause of this?
1) Was the turn too sharp and the system shutdown automatically?
2) Is it because my power steering fluid is low? If so, how can I check?
3) There is a red cap on my engine and I don't know what that is. Is it my engine oil or is it power steering oil. Can anyone look and elaborate please.
Old Oct 19, 2014 | 08:11 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
n/m
Old Oct 19, 2014 | 08:12 PM
Vanquish59's Avatar
Originally Posted by HeissRod
n/m
Do we usually get a warning light for low fluids in general?
Old Oct 20, 2014 | 04:22 AM
Elhonaz's Avatar
W211 E55 2003
nothing to do with any fluid levels.. The red cap is a cover to the oilsticktube as there isnt an oilstick on these cars. This didnt go away after restarting, or did it even start anymore? Sounds like something related to the antitheft system is acticvated and its locked the car down
You should get it hooked to star and see whats the code its giving! Could be numerous things!
Old Oct 20, 2014 | 12:55 PM
Vanquish59's Avatar
After turning the car off then on, it worked. Just wanted to know why it locked... Also from the pictures does it seem like my oil level is a bit low?
Old Oct 20, 2014 | 04:10 PM
Rallyboy383's Avatar
2004 E55
Either check your oil using the proper Mercedes dipstick or use the menu on the dash to check it electronically. Do not add any oil until you properly check it. That red cap is only a cover. Your dipstick goes into the hole that the red cap covers. I hope this helps.
Old Oct 20, 2014 | 08:01 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Most likely...
Ignition switch. Beginning to become an issue on these cars...
Old Oct 21, 2014 | 12:55 PM
Vanquish59's Avatar
interesting... didn't know this.
