Smoke After Phenolic Spacer Install..VCG Tricking Me?
Old Nov 9, 2014 | 02:13 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hey Guys,
I installed phenolic spacers (I highly recommend) but now I notice some white smoke coming from my header area. Is this a valve cover gasket leak tricking me into thinking it's related to the spacer install? You can see the smoke around the five second mark.
Old Nov 9, 2014 | 02:40 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
man.. sucks to hear.. hope its nothing. any reason why you added that ? were you doing some work in that area ?
Old Nov 9, 2014 | 03:09 PM
berti_00's Avatar
2016 Cls63s AMG
^^brings the heat down a bit, I think someone actually tested it and had some great results. I bought mine from a member they were from evosport and their price was some ridiculous $299 but I only paid $100. Anyways I've never had any issue and I have taken them a part a few times too..
Good luck B hopefully nothing big. My bet is valve cover gasket. That side is notorious for leaks, I re did mine twice or 3 times lol finally got it and it's been perfect
Old Nov 9, 2014 | 03:31 PM
cm60k's Avatar
^Agree with Albert^,
phenolic spacers are great for heat insulation,
maybe something wrong during installation, spacers cracked within over tighten bolts/gaskets got slips,,
did you check any kind of air leaks/strange sounds around their area..?
ZAYED,,
Old Nov 9, 2014 | 03:32 PM
viper04's Avatar
Berti
Do you have the link of the "test" would like to see the link. Interesting for sure.
Thanks.
Old Nov 9, 2014 | 09:37 PM
OCKlasse's Avatar
MBworld Guru
ZAYED,,
I pulled the air boxes out after and all I noticed was some fluid on the exhaust manifold, nothing else. That could only be from the VCG and not the surge tanks correct?
Old Nov 9, 2014 | 09:38 PM
OCKlasse's Avatar
MBworld Guru
Originally Posted by viper04
Berti
Thanks.
You know how hot your surge tanks normally get after driving? They are only a little warm to the touch after the spacers.
Old Nov 9, 2014 | 10:38 PM
viper04's Avatar
OCKlasses
Thanks for the reply. Your using the surge tank spacers and and not the supercharge ones?
Old Nov 9, 2014 | 11:58 PM
OCKlasse's Avatar
MBworld Guru
OCKlasses
correct.
