Old Jun 10, 2015, 02:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior Guides
Print Wikipost
Really?? we HAVE to use OEM Wiper Blades?
Old Nov 15, 2014 | 03:05 PM
fergsc32's Avatar
2011 c63 AMG
either im losing it or I just am not aware but I just bought some rainex latitude blades and went to replace.. and ive never seen a mount system like ours.... its got the pin but the little bracket we have eliminates the possibility to use any of the clips etc on the blades i bought...... are we relegated to only OEM blades??.. or do we have a select few only to choose from
Old Nov 15, 2014 | 03:14 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
don't be cheap go get new oem ones
Old Nov 15, 2014 | 03:38 PM
fergsc32's Avatar
2011 c63 AMG
latitudes/icons/valeo 900's etc are not cheap...50 bucks or so a pair.....but ive never seen a car where you couldn't replace with a high end alternative...
Old Nov 15, 2014 | 03:49 PM
Toadster's Avatar
2005 E55 AMG
I got a set of Goodyear wipers from Costco with the correct brackets $3.99/ea 😃
Old Nov 15, 2014 | 03:50 PM
fergsc32's Avatar
2011 c63 AMG
ya i tried but my costco carried everything BUT the 26 inch
Old Nov 15, 2014 | 06:05 PM
poohlvhun's Avatar
e55 amg
So where is the cheapest place to buy oem ones?
Old Nov 15, 2014 | 08:01 PM
SICAMG's Avatar
2005 e55 AMG
Ebay!! Exact fit, work perfect and cost 13.95 for the pair.I bought 4 pairs to keep in stock since I change them often.
Old Nov 15, 2014 | 10:05 PM
SPatykAMG's Avatar
W211 E55
I used the bosh icon blades with no problems at all. Maybe you are just over thinking the install. As far as I know the rainex should work fine.
Old Nov 16, 2014 | 01:46 AM
cetialpha5's Avatar
I got some at rockauto. They actually have Trico blades on clearance, $3.81 each. I just got Bosch clear advantage, they were $6.73 each. I also got a set of the Bosch OEM blades which were $31.79 for the pair just in case the cheaper Bosch ones don't last. The clear advantage seem fine so far. There's also a 5% discount code floating out there that makes up for some of the shipping that they charge.
Old Nov 16, 2014 | 11:12 PM
02C32guy's Avatar
2005 E55
I have have rainex wipers on there now. You just need to use the right adapter. The pin just slides through the blade.
Old Nov 16, 2014 | 11:26 PM
fergsc32's Avatar
2011 c63 AMG
Yes the pin slides through... With no adapter...But it is in no way an appropriate fit..far too much play compared to OEM and thats not acceptable to me. Only adapters are the hook adapter..and the snap over the pin one and neither will allow install.
I'll just stick to OEM..or at least test fit before purchase
Old Nov 17, 2014 | 08:57 PM
poohlvhun's Avatar
e55 amg
ebay link pls?
Hey I can't find any in ebay, do you have a link?
( sorry my google-fu is bad...)
Thx!
Old Nov 17, 2014 | 09:12 PM
fergsc32's Avatar
2011 c63 AMG
Thx!
I saw these below....also I looked carefully at the latitudes I got on ebay and they seem to be an older style..they just plain don't work glad it was only 11 bucks for the pair !..I saw the new ones at walmart and can see how they would work...
anyway..here is an ebay link I found
http://www.ebay.com/itm/251006825466?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Nov 17, 2014 | 09:18 PM
RikTT's Avatar
A bunch of TT's
I bought a set from Autohausaz while I had an order in for a few other little things w free shipping - Bosch Aero Twin. Same price as other $15-$20 blades out there. My previous ones lasted way long enough so why not back to it. If you are deal with cold climate/snow/ice, a good set will be warranted.
Old Nov 18, 2014 | 02:12 AM
cetialpha5's Avatar
2003 2009 Mercedes Benz E Class AMG W211 Beam Windshield Wipers Wiper Blades | eBay
I think those are knock offs or clones. They don't actually say Bosch on them.
Old Nov 21, 2014 | 05:35 PM
starbrite's Avatar
2004 E320
I just change the rubber blades by buying Anco 31-26 from my local Walmart, pulling the blades, and mounting in the oem wipers. Total= $7.18 :
Amazon.com: ANCO 31-Series 31-26 Wiper Blade - 26", (Pack of 1): Automotive Amazon.com: ANCO 31-Series 31-26 Wiper Blade - 26", (Pack of 1): Automotive
