UPD Torque converter 3000 stall
Old 12-14-2014 | 10:23 AM
99lightning's Avatar
99 ford lightning
hoosier drag radial and that was before posi doing one legged burnouts. then I added posi and headers and that's when it went downhill traction wise. the 1.64 was barely up on the convertor.
Old 12-14-2014 | 04:07 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Is there anyone who can prove ,with time slips , that they picked up a better 60ft time ,better qtr mile time,without losing mph in the traps with this converter,I'd be willing to give it a try,however I was told by some other members running 10 s that I should NOT change converter,all guys running tens with 1.5 60 ft on stock converters ,at least the guys I spoke to,my best 60ft was 1.59 most are in the 1.6s, hell I got a 1.61 with my pilot super sports on prepped track, like I said ,I'd try it if somebody could disprove what I was told,I am running an SL55 tho not E .
4295 lbs with driver
506 WHP Mainline Dyno
Best ET 10.77@130.38
Old 12-14-2014 | 04:44 PM
99 ford lightning
tell you what I will get a sticky tire on the car and show you a e55 busted in half when I launch
Old 12-14-2014 | 07:18 PM
cnterline's Avatar
Wow , RedBullJunky running 10.2 and his car is still in one piece ,as far as I know
Old 12-14-2014 | 07:32 PM
jcjmw's Avatar
2005 E55 Wagon
I believe there is a thread by redbulljnky about how his times improved bc of the higher stall TC.
Old 12-14-2014 | 08:10 PM
cnterline's Avatar
I did remember reading that thread ,but his car is TT , I think he launches it different then I would ,right now I can dead punch my car ,best I got was a 1.59 maybe if I go extreme light rims and tires with skinnies up front I can do a little better but was looking for a 26 to 2800 stall,I think 3000 will blow the tires,
Who knows
Old 12-15-2014 | 05:27 AM
  #32
99 ford lightning
The stall changes the game stock stall I don't care what power you have or track prep hooking is easier. Like with the lightnings stock stall guys even with way lower hp then our cars can pull 1.8 to 1.7 on street tires, add drag raidials with a stall maybe a high 1.6 add slicks to that stall low 1.6 to 1.5's I was amazed with the stall on the 55 that I could lose traction yet still pick up on a sixty foot and et and mph. I wish they made a 16 inch full slick for our car, but the hoosier qtp is the closest thing.
Old 12-15-2014 | 10:51 AM
  #33
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by SoloMotorsports
We here at SoloMotorsports just love the 3000 stall converter from UPD. We installed 4 of them so far. Great product from UPD. We are authorized dealer for UPD. Let us know if you guys have any questions.
Nice clean install and you must be giving test rides, as customers are lining up for 3000 stalls over there (like air Jordan`s on sale)
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 12-15-2014 | 02:56 PM
  #34
Denroll's Avatar
'06 E55
Originally Posted by edan82
We'll, anyway I'm getting a new OEM converter in few weeks
How much did that OEM unit cost? I'm going to put mine on eBay, but I need a ballpark figure for it. I have been unable to find a used one listed.
Also, still looking for a P030 rear end. I run a search every day and have not seen one come up in almost 3 months.
Old 12-15-2014 | 11:25 PM
  #35
edan82's Avatar
2003 E55 AMG
my garage qouted me around 1500$ for the new OEM converter.
anyway, im getting it free of charge from the garage who rebuilt my transmission.
Old 12-16-2014 | 03:14 AM
  #36
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
Usually stalls drop ET by 2-3 tenths but also lower the MPH some. What did the stall install cost you guys ?
Old 12-16-2014 | 08:22 AM
  #37
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
I always heard that it lowered your MPH but everyone here says that it raised there's! Something fishy is goin on here!
Old 12-16-2014 | 08:33 AM
  #38
99 ford lightning
mine went up 1mph going from hooking and negative 500da stock stall to stall spinning and 800ft da. Lock up clutch is strong as a mother and pulls like a freight train. so 1mph under totally different traction and da conditions is a plus it certainly did not go the other way. Its like with my 3.06 gear my car totally messed up at the track with shifting and everything else under the sun and still picked up 2mph from the gears. mine is making power and when it all comes together I will give you folks something to talk about.
Old 12-16-2014 | 09:16 AM
  #39
PLATINUM SPONSOR
2003 CL55
A well built and well set up converter for your power/torque will increase mph, as it is more effecient and you will stay in your peak power band longer and drop less rpm at the shifts. Roll racing power will also improve, increased "grin" factor by staying in the sweet power spot, for when you have to drop down against manual tranny car.
I driver my car daily with the UPD 3000 stall and it is one of my favorite power mods.
__________________
www.ultimatepd.com
Old 12-16-2014 | 10:29 AM
  #40
SICAMG's Avatar
2005 e55 AMG
These transmissions lock up right after it shifts to second gear, at least mine does....I feel the shift than the lock up bump that's real firm. Is that what you feel when driving it under power?
Old 12-18-2014 | 07:47 AM
  #41
60nomad's Avatar
Sounds interesting...might give it a shot after the winter.
Old 04-01-2015 | 09:16 PM
  #42
PLATINUM SPONSOR
2003 CL55
Looks like the snow is melting bro. You game yet?
__________________
www.ultimatepd.com
Old 04-02-2015 | 10:48 AM
  #43
blackbenzz's Avatar
haters crazy
These converters have been out for a while now. Anybody running in the 1.4x's yet with these or all the fastest 60's still with stock converters?
Btw, your mph will go up when spinning without any changes in the 1/4 mile
Exotic metal- Your car is heavily modded with UPD stuff. Why don't you take it to the track to promote your products?
Old 04-02-2015 | 11:16 AM
  #44
03svtkiller's Avatar
2011 Cadillac CTS-V
I would have to agree with most on here, this is probably the best mod for the buck. track times not sure yet but soon as it opens here we will see how she does...
Old 04-02-2015 | 01:15 PM
  #45
99 ford lightning
does the mph go up to when you have to lift too. stop hating on the mans products.
Old 04-02-2015 | 01:21 PM
  #46
blackbenzz's Avatar
haters crazy
Is asking for results hating? So far I have yet to see a car come even close to the same 60's as stock converter cars. If it's such a great product why is that? I'm not hating on the product. I just want results. In theory it sounds like a great product and the company that actually makes it (not UPD) is a good company. I'm confused as to why it hasn't translated onto the track
Also, he is a reseller. He doesn't make these products.
Old 04-02-2015 | 05:04 PM
  #47
99 ford lightning
dude everytime you ask for results we give them to you, and you knock it down. stock stall is way better blackbenz are you happy.
Old 04-04-2015 | 12:25 AM
  #48
Kwik SC's Avatar
2003 S-600
Will this convertor work on an s600 with the 722.6 tranny? Has anyone tried it?
Old 04-04-2015 | 07:56 AM
  #49
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Yes it will work on the s600. PM me of you need one
Old 04-04-2015 | 11:44 PM
  #50
dllhg's Avatar
I have always heard and experienced lower ET along with lower trap speeds once a stall is put on. Roll racing is better as well. Never heard of higher trap speeds.
What does the labot book out on doing a stall for our cars ? Also is more cooling needed ? Stall increases operating temps quite a bit.
Quick Reply: UPD Torque converter 3000 stall
