rough idle- changing engine coolant? radiator? transmission fluid? brake fluid?
Old Feb 7, 2015 | 02:32 AM
benznewcomer's Avatar
porsche
for a used vehicle purchase would you change either of the following on an e55 2003?
PPI said could be possible rough idle issues.... would it be best to:
1)changing engine coolant?
2)radiator? may still be using the stupid old valeo problematic radiator
3) transmission fluid? head not to do this until 150000 miles
4) brake fluid?
any other "definite" fixes you would do if you just bought an e55 2003?
Old Feb 7, 2015 | 03:34 AM
menace2sobriety's Avatar
2004 E55 AMG
4) brake fluid?
Rough Idle?
Plugs
Leads
Coils
Vacuum Leaks
Old Feb 7, 2015 | 05:25 AM
porsche
ah thank you i appreciate the reply, forgot about the spark plugs
the fluids are needed to be changed too or not really?
Old Feb 7, 2015 | 05:42 AM
2004 E55 AMG
If you have just purchased the vehicle, I would change all fluids and basic parts, mainly for piece of mind so that I knew those common maintenance parts were ok, Trans, Diff, SC, Plugs, Leads, Coils, Oil, Oil Filter, Air Filters
Old Feb 8, 2015 | 12:16 PM
GregMB's Avatar
Except for the transmission fluid...
If the car hasn't had regular maintenance the only thing holding your transmission together is the friction material floating around in the old fluid. If you flush the tranny with fresh fluid you will probably end up doing a transmission rebuild a few weeks later.
I've seen it happen several times to people on this forum. They claimed the service tech did the flush wrong, but in reality the clutch packs were just completely worn out.
-G
Old Feb 8, 2015 | 12:28 PM
Hulk's Avatar
A Merc
As gregmb said, just drop the pan and refill what is missing
Old Feb 8, 2015 | 02:14 PM
desired_speeds's Avatar
2007 SL55 AMG
More than likely, the rough idle is from your plugs/ wires. As mentioned above you should change all the fluids after purchasing. For transmission, a pan drop/ filter change is recommended. Do not flush with a machine.
Old Feb 8, 2015 | 05:52 PM
porsche
thank you all its appreciated
Old Feb 8, 2015 | 06:19 PM
porsche
do you think changing the engine coolant will help in anyway?
Old Feb 8, 2015 | 08:33 PM
2000UZJ's Avatar
E55
Engine coolant will not help.
