Another Airmatic Threat
This winter, I haven't driving my car much - it actually sat in the garage for 2-3 months. However, in the garage, I realized that rear end of the car was very very low. I started the car and it said wait for the car to raise. it raised to the normal level and I drove the car that day. Since then, every night, rear end of the car floors (one side more than other but both sides are very low) and in the morning, it raises when I turn the car on.
I am fine with replacing the rears with Arnotts however, I want to make sure that is the problem. Front of the car is very good and at the right level all the time.
I checked the connections to the reserver air reservoir connections with sopy water and they seem fine. I also check the 4 connections next to the pump in the front and they were good as well. I dont know what else to check before saying the struts are leaking. is there any way to check the struts to see if they are leaking?
Thanks.
ps. I searched the forum and read a ton in the last two days but wanted to get your opinion on the specific case. what would you recommend?
At one point, I had replaced the fronts and not the rears and the rears would often drop over night in cold weather, the fronts would stay up. After replacing the rears with Arnotts, the rears never drop even after a month of sitting .. although I have moved to a warmer climate now.
Sounds like they are on their way out but not quite there yet. Mine was the same but I chose to just replace them and not worry about it after that.
One more thing you might try is to leave it in the raised position .. .I noticed on mine that if I left the car in the raised position overnight (before I changed rears) it would not go down, but if I left it in the lower position, it would drop .. not sure why that would happen.
http://www.carid.com/2006-mercedes-e...-39487781.html
