40 Ohm 5 Watt resistor works for side marker lights
Old Mar 22, 2015 | 07:29 PM
moehler's Avatar
2014 CLS 63 S AMG / 2004 E55 AMG
An FYI thread...
I bought a 2004 E55 with an E63 bumper conversation. It was throwing an error for missing the side marker lights. Given the 5W bulb had roughly 40 Ohms of resistance, I wired in two 40ohm 5 watt resistors and they have worked out great with zero issues.
They are not a very common resistor... Here is the exact eBay link that I bought them from:
http://www.ebay.com/itm/390392689882?redirect=mobile
Old Mar 22, 2015 | 08:00 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Thanks for sharing .. in case you didn't know, it can also be coded out using STAR by setting Gateway to ROW (Rest of the World).
Old Apr 8, 2015 | 09:51 PM
rodneypierce's Avatar
2009 e550 4Matic
Im curious if the wattage matters...
Old Apr 8, 2015 | 10:48 PM
turbo97se's Avatar
If it is higher, it is OK. If it is lower, you risk burning out the resistor as it will get hot. The power (or wattage) of the resistor indicates how much power it can handle/dissipate.
Old Apr 9, 2015 | 12:20 AM
desired_speeds's Avatar
2007 SL55 AMG
The best way to turn them off is to go into star diagnostics and set central gateway to "Rest of World". Your sidemarkers will turn off, your fog lights won't turn off when you hit your highbeams, and your SBC H / SBC S will work!
Old Apr 9, 2015 | 01:27 AM
turbo97se's Avatar
Exactly what I said ... I see you have a 2006 - does your SBC S work? After 2004 they are supposed to have turned SBC S off completely, it does not work on mine
Old Apr 9, 2015 | 03:46 AM
2007 SL55 AMG
Haven't changed my 06 to ROW yet. Worked on my 04 though. I'm starting to like 06's less and less.
Old Jun 16, 2016 | 03:10 PM
LoveMyAMG's Avatar
05 E55 AMG, 05 S2000
I have been searching soooo much for this information.
I have an 05 E55, i just did the E63 conversion in the front. I'm trying to turn off the lights on the bumper that are from the E55. Could someone please help me out how to do this?
i've been reading to switch to ROW on CGW. However what I cannot find where this menu is located, also if it effects any other aspects of the car as far as programming?
Old Jun 16, 2016 | 03:38 PM
compaddict's Avatar
2016 S63, 2013 SL63
Thanks!
Old Aug 20, 2023 | 07:13 PM
Rob E.'s Avatar
04 mercedes-benz e320 4matic
Originally Posted by moehler
An FYI thread...
Jan RER60F40R2R 40 2 Ohms 40 2OHMS 5W 1 Power Resistor Milspec | eBay
having same problem 2004 e320 4matic tried two diff dynamic marker lights t10 they shhot can bus err9r please help i got 12vokt 6ohm resister from auto zone.
