Sacramento raceway today 4/4 test and tune 12pm-4pm
Old Apr 4, 2015 | 10:19 AM
lm7's Avatar
lm7
2003 E55
Hey guys super late post but I figured I'd post anyway. I'm heading to Sacramento raceway today for test and tune. Leaving San Jose about 9am gates open at 10 test and tune runs from 12-4. If anyone can make it out or want to join let me know!
Any estimates on what ill run?
2003 e55 127K
Weistec 180mm
UPD 83mm upper
Trunk tank/killer chiller/ meth comes in at 90 degree iat
90mm bbk TB
mBH long tubes x pipe no secondaries just mufflers
Ported heads
BIP box tune
BIP TCU
UPD 3k stall
Quaife diff
Clk wheels/ mt drag radials
Old Apr 4, 2015 | 10:54 AM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Nice mods. If you can get traction I would guess high 10's..
Old Apr 4, 2015 | 01:11 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
2003 e55 127K
Weistec 180mm
UPD 83mm upper
90mm bbk TB
Ported heads
BIP box tune
BIP TCU
UPD 3k stall
Quaife diff
Speaking from experience, at Sac traction will be key since VHT seems to be a foreign word there. Start your air pressures at 20psi, heat the mickeys up really nice and roll out of the burn out. Power brake up to take the slack out of the drivetrain and launch off idle. Suspension raised, DC setting on soft and if you get the launch right 1.65 or better and you don't pull timing you could see a 10sec run. Make sure you drain some water from your tank but not below the pump line and then stuff it with ice.
Park close to the staging area so your ice doesn't melt as fast during staging and the burn out. Off to the right of staging area u will see a blue fence with some grass/moss setup shop there.
Goog Luck hope to hear 10's later
Old Apr 4, 2015 | 02:06 PM
Toadster's Avatar
2005 E55 AMG
good luck! hopefully they have the track prepped good!
Old Apr 4, 2015 | 05:45 PM
lm7's Avatar
lm7
2003 E55
Well that was fun. Couldn't manage better than 2.0+ 60ft blazing 11.80 best pass of day 121mph. Back to the drawing board...
Old Apr 4, 2015 | 07:01 PM
kustom2k1's Avatar
03SL55
MPH seems low for mods listed. Then again if you spun for half the track it'd make sense.
Old Apr 4, 2015 | 08:24 PM
lm7's Avatar
lm7
2003 E55
Yeah I think so too, not really sure why. In any event will just keep trying, we'll see.
Old Apr 4, 2015 | 08:33 PM
Ls1toAMG's Avatar
Well with those mods you need a dyno tune. A box tune is ok but your leaving a lot on the table without it being dialed in.
Old Apr 4, 2015 | 09:13 PM
So tell me what/how you went about it? There's a certain touch that Sac requires. Back in the day the SoCal AMG crew came up to Sac thinking that they could duplicate Alan (Bassn07) Mike (MikesAMG) and myself times. They all blew the tires off and couldn't hook up worth a Sh**. I would put money on it that I could better your times in your car. I would also think that your box tune has to have some Craig influence behind it.
I bet your ecu was cutting power like a **** with a 2.0 - 60'
Old Apr 4, 2015 | 10:04 PM
lm7's Avatar
lm7
2003 E55
Started at 22psi (best 60 of the day) and went down to 18 psi. Short burnouts and slight load up to flash from idle. I'm not really sure that I like this converter setup it just hits the tires too hard. I hear you on the prep at sac being tricky but I've done better with much less mods so just have to sort this setup out. Not really sure about you bettering my time but I'm down to race you in your car against me in mine for money, Let me know?
Not sure I'm following you the Craig influence part...what does that mean?
Old Apr 4, 2015 | 11:58 PM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Did your brother run his E55 Carlos? You need to get a belt wrap kit back on your car, what changed since last time you ran an 11.3?
Old Apr 5, 2015 | 05:29 AM
20 psi is the ticket with the MT's and burnout is key, 18psi made car a little bouncy as I crossed the line and I didn't like that feeling so I went back up to 20psi. Sorry but I don't race for money, hell I don't even race anymore but I think you took my statement to literal. One of the SoCal guys I was talking about came with his E63 on street tires and couldn't get lower than a 12.4 or 12.5. I got behind the wheel never have driven a E63 and ran 12.2 on my 1st run.
Craig (CHawkins) had his car tuned by BIP and is very good friends with the and he has tried many setups so I figured that they developed your box tune from gaining data from his car.
I've never driven a car with a stall so I don't have any experience I can offer with the loading or not loading of the drivetrain. The majority of my strip experience was when my car was stock. I've only made 5 passes since my car has been modded. Was this your 1st time with this setup at Sac?
Old Apr 5, 2015 | 06:36 AM
99lightning's Avatar
99 ford lightning
with the stall you simply need traction and tires its a different beast.
Old Apr 5, 2015 | 12:19 PM
lm7's Avatar
lm7
2003 E55
No he didn't. I can't get it to stop shredding belts but I agree looking at the logs boost is inconsistent.
So much has changed since those times, I added a quaife, heads, meth, new upper and lower pulley combo, different tuner, different tires. In theory I should have gained mph or at least bettered my ET but it's going slower ET ****tier 60ft and same mph.
Plans are dyno tune, different crank pulley, belt wrap kit back on, 315 hoosier, adj. Camber arms and that's really all I can think of for now.
Old Apr 5, 2015 | 12:22 PM
Hulk's Avatar
A Merc
Ya your mph should be higher, something is up. Was timing being pulled back?
Old Apr 5, 2015 | 12:26 PM
lm7's Avatar
lm7
2003 E55
I see yeah the DRs like more psi from my experience but the trick is finding how much you can run and still hookup. That's cool I've never run into any other w211 guys at sac but I only have been a couple times in this car.
I'm going to see if Tony can dyno tune it and make some other adjustments with the setup.
Old Apr 5, 2015 | 12:48 PM
I would stick to the 16" clk set up but switch to the Hoosiers 255/50/16 they are stickier than the MT and they are 6lbs lighter. If I had continued racing I would've switched to the Hoosiers. Next time you go let me know and I will meet you up there to lend a hand or whatever you need. If I were you now this is just my opinion I would switch back to the stock supercharger pulley and go with a ASP 185 with the aluminum outer ring. I would've gone this route but I bought my 185 from Shardul before they stated putting the aluminum outer ring.
Old Apr 5, 2015 | 01:14 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
That's a 10 sec recipe
Old Apr 5, 2015 | 05:47 PM
lm7's Avatar
lm7
2003 E55
That's what I'm hoping lol!
Old Apr 5, 2015 | 05:51 PM
lm7's Avatar
lm7
2003 E55
Not a bad idea I may end up going that way. going to dyno tune get new tires and try again on the 25th.
Old Apr 7, 2015 | 01:26 AM
Btw who did your head work? I was thinking of buying a second set of heads and then take them to Robello or Top of the Hill Performance
Old May 9, 2015 | 12:04 PM
lm7's Avatar
lm7
2003 E55
Going to the track today Sacramento raceway for test and tune of any one is planning on going let me know!
Old May 9, 2015 | 05:13 PM
How did it go?
Old May 9, 2015 | 05:46 PM
sircl55amg's Avatar
2006 cls 55 amg
that's a 10s set up for sure
Old May 10, 2015 | 04:55 AM
lm7's Avatar
lm7
2003 E55
It was a bit warm. My new wheel setup has it consistently 60ft a 1.6 best time was 11.32@122.
Gonna get a retune, its super lean in first gear and look for some better weather.
