80mm or 82mm?
Old 04-10-2015, 12:23 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
Originally Posted by shardul
cost. unless you would like to say 400 plus for the 80 snout and what ever the flanges go for these days.
with the flange the y pipe and air boxes are post back toward the firewall by the thickness of the flange which sometimes will result in air boxes not being fastened to the original mounting points on the valve coves
Ok, do the bolt holes have to be moved on a 74mm snout to accommodate the 82mm TB? I was always wondering if the 74mm had enough material to bore out 8mm additional. I sure do like the idea of not having to run/weld an additional flange, so this seems like the way to go. What else ahs to be modified with the 74mm besides boring it out to 82mm?
2006 and up sl55
Sweet, thank you . Is that the 80mm? or the 82?
Old 04-10-2015, 12:28 PM
Hulk's Avatar
A Merc
For the stock plenum you will need to cut off and bore to 82mm then find a plate to weld onto the plenum to screw into the 82mm tb
The sl55 plenum will be 80mm
Old 04-10-2015, 12:32 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Originally Posted by ghlainez
Hulk, if you just port the stock pletnum why would you need a spacer?
you can port match the 74mm inlet to the 82mm and then add material on the top to mate it to the OEM MB 82mm
like this. cleanest and most cost efficient way to mate a 82mm to a factory inlet
https://mbworld.org/forums/engine-pe...ed-plenum.html
In the pic you can see the bottom mounting position is OEM (74mm inlet)
Old 04-10-2015, 12:39 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Everything you need for the 82mm tb
-MB 82mm t/b: 2731410325
-82mm t/b gasket: 2731410680- 14.61 retail
-80mm s/c inlet: 1131400912- 436.80 retail
-s/c inlet gasket: 1131410780- 13.78 retail
-80mm Y-pipe: 1130900329- 286 retail
-O-rings for Y-pipe: 90025K396 (www.mcmaster.com)
Have the snout bored to match the 82mm and if needed add material to the snout so that the screw holes can be relocated so that the 82mm can bolt up to it.
Old 04-10-2015, 03:48 PM
m3j0n's Avatar
just bought a new OEm 80 mm sc inlet...
m3j0n's Avatar
I move fast... lol...
Quick Reply: 80mm or 82mm?
